Every used TSX I've driven has a shimmy in the steering wheel...
Is this a common problem? A few have also had a noticeable brake shudder. I hate it when my cars do this. Anyone else fighting these issues or have I just run into a bunch of poorly maintained cars? Is balancing included in the warranty coverage?
Thanks!
Thanks!
Were these cars you drove new or used?
My brakes started vibrating a little while ago. I replaced the rotors & pads with Power Slot rotors & Hawk pads and I have no more vibration or shimmy. This was at about 28,800 miles. I've now got just under 30k.
Got Phó?
What tires are on these cars? Some tires (like my Avon Tyres Tech M550s) will flatspot if the car is parked long enough, causing slight steering shimmy until the tires warm up again (usually takes me about 5 minutes of highway driving).
Originally Posted by Newplay1
I think he said every USED cars, so I'm guessing he is shopping for used tsx..
Anyway, I replaced all four.
Originally Posted by TonySX
They all had Michelin HXM4 or something like that. All the cars had around 12-20K miles on them.
Well I'm close to buying one pending a balance and another test drive. It hink he's taking it to an ACura dealer though since he believes they'll do it under warranty. Do the Acura dealers have Roadforce balancing?
its the brakes......., the rotors warp easily. Especially if your drive your car hard and use the brakes alot. I just had mine replaced / resurfaced under waranty......., but I think I can already feel it happening again........ gonna have to bring it back in and tell them that this isnt going to work. I think the brakes are undersized IMO.
Rep'n Taxbrain.com
^^ Some dealers will cover it if you say they that you're getting a lot of weird vibrations, etc. If you buy used and end up with the brake shuder, I would recommend getting some new aftermarket rotors such as the RacingBrake or Brembo blanks. A lot of the people running the OEM rotors, including myself, have gotten the shudder that you're talking about.
Me too. Shuddering is happening. 33K miles and it seems to be getting worse! Only really noticed it at around 28k or so.
Is it a buildup of crud on the pads/rotors or is it truly warped rotors?
cycdaniel
12-17-2019 10:58 AM
JByron
01-08-2016 09:49 PM
