ETM question
For the navigation bus the Acura uses GA-NET II, which is nothing more than NEC's IEBus protocol. That is the project that I am currently in the middle of over here: AC's Touchscreen Interface. I have also started a wikipedia article about the IEBus here: wikipedia.org
If its the engine stuff you are looking for then that is over CAN. There is a LOT of information about that on the internet and a quick search on google can get you started.
'06 TSX 6MT
thanks.- basically i'm looking to see what would be involved in writing a software package similar to the HDS, and hopefully a bit more- maybe tap into the '06 MFD etc, add security features, etc.
'06 TSX 6MT
sorry i work in engineering and our language is either TLAs or off the FLAL.
HDS: Honda Diagnostic System- the system the dealer hooks up to your car to do diagnostics, register keys, reset settings, etc.
MFD: multi-function display- the thing on the gauge cluster that tells you fun info like "gas cap loose, and check emissions system", or your gas mileage and temperature
TLA: three-letter-acronym
FLAL: four-letter acronym list
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
