Engine Start Button Install
Old Apr 15, 2011 | 09:26 PM
Euro-R_Spec_TSX's Avatar
Brock
I can't believe that nobody has done this (until now). Although I have to admit it's kind of useless. None the less it's pretty cool and fills in the 2 empty switch locations in my 04 TSX.
First off, the TSX ignition switch is the same as an RSX, so the DC5 Type-R Start Button kit from ICB Motorsports is a direct fit. The only thing requiring actual modification is the start button switch bezel because the DC5 panel is flat, where as the TSX is curved. It's still not a perfect fit, but doesn't look too bad, as you can see in the pics.
If anyone else is interested in doing this, then let me know and I will post a complete "how to".
Old Apr 16, 2011 | 08:13 AM
huludicidal's Avatar
Almost Doctor
Is the key switch still operable to start the car?
Old Apr 16, 2011 | 08:19 AM
Simba91102's Avatar
Old Guy
Looks pretty cool, and.... you have once again confirmed my oft spoke contention that this site is largely populated by guys with waaaaay too much time on their hands. Oh.... good job.
Old Apr 16, 2011 | 09:38 AM
Brock
Yes, the engine start button is basically in parallel with the standard key switch. You can use either method to start the engine.
Old Apr 16, 2011 | 01:42 PM
robles325's Avatar
Nice installation man! How much did the kit cost you? and how hard was the installation?
I suggest you post the DIY method so other people can get interested, because I'm surely am.
Again, Nice Job
Old Apr 16, 2011 | 02:32 PM
Brock
Again, Nice Job
Thanks!
Price is $270, but comes with everything you need except a nut/bolt for the ground eyelet and a wire splice. Here is a link:
http://www.icbmotorsport.com/jdmindcacstb.html
I'll post the complete DIY shortly. Just have to edit some pics...
Old Apr 16, 2011 | 03:19 PM
Jaan Lewaa's Avatar
button n key both works? means u can start by either one?
i read some where here or that u have to have key inside to start with the "start button" but it doesnt start with key
BTW gr8 job *thumbs up*
Old Apr 16, 2011 | 03:41 PM
Brock
Complete DIY...
Here are some pics of the DC5R engine start button kit:
Relays, switch, tie wraps, etc:
Wire harness:
Relays installed:
Clutch lockout wire/connector:
OK, first you have to remove the following trim panels: left under dash, front lower under steering column, steering column top and bottom, and the switch panel.
Next, find the clutch lockout switch and disconnect it. This is only because it is easier to connect the wire splice to it with it unplugged.
Next, disconnect the ignition switch connector (large brown connector).
Next, plug in the ignition switch connector on the start button harness to the ignition switch and the original connector to the mating connector on the start button harness:
You'll want to tie wrap the new harness to the existing harness as tightly as possible so that it doesn't interfere with the steering column trim.
Next, find the available screw boss and use the supplied M6 bolt to fasten the relay cluster to the dash support beam. It's in the middle of the pic. Almost looks like it was made for this mod!!!
Next, connect the ground eyelet to the support beam using a nut and bolt (you have to supply). I used an M6 flange nut and bolt. There is a hole in a suitable location for this:
Next, connect the lt green wire on the start button harness to the lt green wire on the clutch lockout switch harness using a splice connector. Before doing this you have to drill out one side of the splice with an 1/8" drill to accommodate both wires going all the way through.
Now plug the original clutch lockout connector back into the clutch lockout switch. The connector on the start button harness will just hang free. You can tie wrap it to something if you want, but I just left mine hanging loose.
Next, feed the start button harness with the green connector through the panel opening.
Actually, you're not ready yet to connect the switch because you have to modify a couple of things. First the metal support behind the switch panel needs to be drilled and sawed to provide clearance for the start button. I first used an 1/8" drill to make a pilot hole which I then used for a Rota-Broach cutter. Sorry I didn't take a pic of this tool, but it works great for making precise holes in sheet metal. After making the 9/16" hole, I used a stubby hack saw blade/handle tool to open the hole. I didn't think to take a pic of this, but I drew lines on the pic showing the hole:
Next, you have to modify the switch panel by removing the center rib between the 2 end switch cavities.
Now that I think about it, you wouldn't have to modify the support beam if you moved the start button over by one cavity, thus having it between the sunroof button and the VSA button.
Next, you have to modify the start button bezel by sanding down both sides so that it fits down into the switch panel. It only sinks down a small amount in the center because of the curvature of the panel, but looks better than riding on the surface. You also have to trim off the small ribs on the back side.
OK, now you can install the switch panel. Be sure to tie wrap the harness underneath the dash so that it is secure. Re-install all the trim panels and your done!
Old Apr 16, 2011 | 04:25 PM
Andy Tsang's Avatar
pretty neat
Old Apr 16, 2011 | 04:33 PM
feuss2's Avatar
10001110101
I'm more interested in that screen in the storage pocket - what is that?
Old Apr 16, 2011 | 04:42 PM
Brock
It's a DGauge, OBD2 Gauge. Fit's in the storage pocket perfectly. www.dgauge.com
Old Apr 16, 2011 | 10:23 PM
theaznboywunder's Avatar
5th Gear
looks good! just a question, does the harness work with AT?
Old Apr 17, 2011 | 10:05 PM
Brock
I see no reason why it wouldn't, but you will have to ground the lt green wire on the start button harness. That's what the clutch lockout switch does when you push in the clutch.
Old Apr 20, 2011 | 12:39 PM
TWONZ's Avatar
That's incredible.
Nice DIY.
Old Apr 21, 2011 | 07:19 AM
psteng19's Avatar
I take it the key still has to be turned to the On position before you press the start button right?
If this was proximity capable with a new key fob, I would be all over it.
Nice DIY though, looks easy enough.
Old Apr 21, 2011 | 08:42 AM
VQPower37's Avatar
very nice ... so do u have to have the key in the ignition to make this work?
Old Apr 21, 2011 | 12:35 PM
mrgold35's Avatar
mrgold35
I would only want a start button if I could keep my keys in my pocket.
Old Apr 22, 2011 | 08:19 AM
Ruby's Avatar
US Navy Seabees
In the S2000 you still need to have the key in I believe this button is from that car.
Old Apr 22, 2011 | 09:30 AM
GianJ30a's Avatar
I win
Looks awesome. Any videos of it working?
Old Apr 22, 2011 | 05:18 PM
cybereclipse's Avatar
私はより良い
+1 video please
Old Apr 25, 2011 | 06:49 PM
jamesjstar's Avatar
6th Gear
Same here, KPtechnologies was supposed to develop one, but never really surfaced.
Old Apr 26, 2011 | 10:09 AM
psteng19's Avatar
KP, you have a guaranteed couple of customers here, if it matters any!
Old Apr 26, 2011 | 03:12 PM
phishie's Avatar
Agreed, I'd certainly purchase one of those. Would love to have a RFID or similar enabled key with a push button start.
Old Apr 26, 2011 | 08:37 PM
VQPower37's Avatar
would love to c a video of it in action
Old Apr 26, 2011 | 10:34 PM
Brock
Yes, you still need the key. Don't forget, the key has the immobilizer chip in it.
I'll try to take a video when it stops raining... in a few days!
The actual start button may or may not be the same as an S2000.
The kit is 100% JDM. It is an accessory item available from the dealer in Japan for the DC5 (Integra) Type-R. See this link:
http://www.honda.co.jp/ACCESS/auto-a...ml?from=rcount
Old Apr 27, 2011 | 11:40 PM
Brock
I updated the first pic because the previous one was taken before I modified the support beam. Also, I have a short vid, but it seems to be a special format (.mts). Not sure what to do and I don't have a youtube account either. Maybe someone else wants to upload the video?
Youtube does not seem to support the .mts file format, so it will have to be converted first.
Old Jun 2, 2011 | 08:51 AM
Chaserz's Avatar
ITR 01-0442
ya cool but agreed useless, lol just an extra something to do to start your car. Fancy Killswitch
Old Jun 2, 2011 | 03:22 PM
Brock
Yeah, the only useful feature is that it helps me remember to turn off the VSA, since the start button is right next to it.
Old Aug 6, 2011 | 09:01 AM
tcxsnoop's Avatar
Awesome write up, thanks
Old Aug 7, 2011 | 05:41 PM
Brock
Hey, no problem.
Just thought other people might want to do this since it's relatively easy.
Old Aug 8, 2011 | 09:55 PM
Juan_Soto's Avatar
Very nice something i wanted to do just didnt want to do it cuz i thought it was going to be to hard too. Thanks and great write up
Old Aug 18, 2011 | 09:12 AM
Moose Muscles's Avatar
Will this work on the 5AT?
Old Aug 22, 2011 | 04:07 PM
Brock
It should.
Old Sep 4, 2011 | 12:39 AM
street277's Avatar
www.advancedkeys.com just finished my install in my 05 a/t works great.. No keys at all with data immobilizer bypass
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
NSolace
Sep 3, 2015 08:02 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
