Is this the end of VTEC?
Photography Nerd
Originally Posted by domn
Maybe in 15 years when these light weight valves have come down in price and have has suffucient testing.
Photography Nerd
Something tells me this will be adopted quicker than 15yrs. I bet we'll start seeing it on high end sports cars in 5 or 6 years and trickle down from there.
I'm sure Hondata will be all over this one! There has got to be all kinds of tweakability with electromagnetic lightweight valves. I think this is going to revolutionize engines as we know them. Cam design has always been a compromise. Really a cam is only optimized for one specific RPM. Every other RPM has less than optimal valve timing. VTEC adds a second cam timing for higher RPM range but this system is far superior. I wouldn't be surprised if given two identical engines except one with the new electromagnetic valves you could see upwards of a 10 to 20% gain in HP across the entire RPM range.
The cams are an archaeic means of valve timing...dating back to the earliest internal combustion engines and pushrods. Overhead valves were an advancement due to their relatively light weight and eliminating the need for the push rods.
Electromagnetically controlled valves will definately revolutionize internal combustion engines for the power necessary to drive the valve train will no longer have to be drawn from the crank thus reducing power,frictional and heat losses.
Additionally the electro controlled valves would be software controlled permitting optimal timing, duration and lift throughout the rev range...which will be awesome !
Originally Posted by toddstuh
I think you'll see them in the F1 racing circuit first. They have the budgets to push this type of technology and then it'll trickle down to the consumer market. I feel that Honda would be a likely candidate for this type of technology...we'll have to wait and see.
BMW has been toying with pneumatic valves for production cars and you are likely to see them relatively soon.
Though I agree with your general point the power to run the valves WILL be drawn from the crank with electromagnetic valve trains, it will just have to change state from mechanical to electrical first, but will likely produce less parasitic losses.
Vandy
Stokeless
F1 should be the first to try this out though. Even though pneumatic has been reliable. I think that they will give it a shot. Who isnt looking for more power?
Moderator Alumnus
I'm sure one of the biggest hurdles they have to jump is the fact that magnets and heat do not go well together.
If it was a big deal, an intermediate solution employing Ti valves on a classic headtrain would still allow for some economy in consumption, increase in performance (valve float issues being offset to somewhat higher rpms), noise, etc.
I actually don't see it happening. First the pneumatic system works extremely well and can produce any valve timing you could with electomagnetic valve trains at the current 19k rpm range, expect this range to stay static OR decrease as F1 rules require engines to last longer and longer. Next the electromagnetic drivetrain would not be as efficient since they would require electricity via either alternator parisitic losses or batteries, either would effect performance more than the current compressed air cylinder which runs the valvetrain for an entire race save a leak (i.e. Kimi @ Indy this year). So bottom line it would likely not produce more power, would be a big risk in terms of reliability and would increase parasitic losses and/or weight. This could all change as magnetics are a growing science but for the near/mid term you are unlikely to see it in F1.
Vandy
IBankMouse
06-13-2020 12:53 PM
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
