effects of removing tint from windows?
Luke 1:37
Originally Posted by goowakjai
i need to have my tint removed and re-done. how will this affects, if any, on the factory windows?
Why you retinting?
Originally Posted by virtualbong
I've never read that there's any effect on the windows, just make sure to be careful removing the rear tint. You don't want to accidentally scrape off the grid defroster connections. If you do, I believe you can purchase some stuff to repatch the places you accidentally removed. I'm sure one of the tint guys in this forum can give you some professional input though.
Why you retinting?
Why you retinting?
thanks VB for the reply. Yeah, the tint is scratched so i need to get it re-tinted.
Originally Posted by Dan Martin
Get some moleskin on there next time...
i asked them about moleskin and they don't know what it is. maybe you can help me because i'm not too sure what it is either except that it helps prevent scratches on your tint. like who makes it, where is it applied, etc. does it go by another name?
i call if moleskin, felt lining, weather striping, window liner, and so on until the person realizes what i'm talking about. if that fails: "you know, the lining that goes between the window and the door to remove water or dirt when the window goes up and down...." for some reason, i'm always tempted to speak slower and louder.
Tuxedo Cat
It's a VERY common solution to a VERY common problem that all quality tint shops know how to deal with.
The fact that they didn't know this and mention it from the start suggests that they aren't that great.
'05/NBP/Ebony/Navi/5T
If it's only 1 window or any window but the rear, easily can be remove. After removing, just use soap & water and new razor blade to scrape of any glue. No effect on factory window what so ever...if its removing the rear window tint, I would not recommend this since most likely it will remove the defrost lines. I would make a claim and get new windows with your insurance.
I used to detail cars and I have removed tint as well......be sure to spray plenty of soapy water on the windows if you scrap with a razor, otherwise you could scratch your glass and have a way more serious problem. If you can find this stuff called "basic H" (not sure who makes it) it works really well. BTW, I wouldn't touch the rear window with a razor at all.
TLDude876
12-28-2016 03:18 PM
BoricuaTL
04-08-2016 01:08 PM
wcimo
09-21-2015 10:55 AM
