Dynamat Hood
Old May 8, 2005 | 03:05 AM
GrOD's Avatar
Dynamat Hood
Has anyone put Dynamat extreme and hoodliner on their car? Does it realy help with engine noise? Just curious...
Old May 8, 2005 | 10:15 AM
Dan Martin's Avatar
Photography Nerd
The hood already has 700 lbs of sound insulation so I doubt it'll do much.
Old May 8, 2005 | 01:16 PM
PixelHarmony's Avatar
Master Graphic Artist
To hood weighs 700 lbs???
Old May 8, 2005 | 02:44 PM
GrOD's Avatar
Thanks for the advise. I am trying to quiet up the noise coming from the engine bay, know any suggestions? I was thinking of putting Dynamat to the hood or dynamat/cascade on the floor.
Old May 8, 2005 | 03:24 PM
arch's Avatar
I doubt youre hearing noise from the hood inside the car. As a former Dynamat Rep I can testify that the hoold liner is very effective at reducing noise, but its not the most attractive product, it does experience discoloration after a few years, and it is difficult to cut perfectly. Also it also retains a lot of heat inside the engine compartment which is a concern in hotter climates. You engine will run warmer and put a little more strain on your cooling system.
Bottom line. I dont reccomend the Hood Liner product. Just Dynamat your firewall, doors, and floor of the vehicle if you have the time. The most significant improvements and reccomended areas of the TSX I would Dynamat are the doors and roof.
By Dynamatting the roof, you would eliminate the tin can sound when it rains on the car. I absolutely must have this done to all my cars. Its not the same, and I cant stand driving any other vehicles in the rain. If done properly, the rain sound should only come from the windshields.
By doing the doors, some wind noise might be eliminated, but the main effect is the doors will sound a little more solid and resonate less in case of a stereo upgrade.
Pay careful attention to the product you select. A big difference is the adhesive compounds each manufacturer uses. Some generic products will sag and fall off under their own weight after a few months or years. Others will crumble and dry out. Make sure to properly prep the application area, use a heat gun to heat the area and dampening material, and take your time.
Old May 8, 2005 | 04:13 PM
TSXsurf's Avatar
NBP/EBONY/6MT
Did you do the roof yourself? If so, how hard was it? It sounds like a smart move, but I'd be worried my headliner would come off after a couple years.
Old May 8, 2005 | 05:11 PM
elduderino's Avatar
VP Electricity
I have also used various products on the hood and find it a poor choice as far as work/results ratio goes.
Hey, Grod, you might want to get a RTA analysis at a stereo store first. Figure out what you're fighting...
If you want to do your roof, Cascade VB2 or 2HD and a heat gun, and it will NOT come off.
And remember tinting cuts noise, especially thorugh thin TSX side glass...
Old May 8, 2005 | 06:05 PM
Alin10123's Avatar
Whoa!
I never knew that!
bluetl04
Aug 16, 2016 02:49 PM
Bielikb96
Sep 28, 2015 10:45 AM
dirleton
Sep 28, 2015 07:05 AM
MilanoRedDashR
Sep 27, 2015 10:15 PM
BookemDanole
Sep 11, 2015 04:53 PM
