Dynamat Benefits?
Dynamat Benefits?
Hi all. I've got a cacophony of rattles coming from inside both of the front doors, so I'm considering removing the panels and going nuts with foam, duck tape, twist ties, voodoo magic, etc.
Also considering using Dynamat, but is there any benefit to use it over just standard foam for rattle-proofing? I don't really have any problems with sound quality. The stuff is pricey but I'm willing to spend the cash if it is worthwhile.
Any advice / experiences with Dynamat / alternatives for rattleproofing appreciated! Thanks!
Nice volition of words! I want to get dynamat too. To create the ultimate luxury sedan experience by reducing cabin noise.
But i'm wondering if the cabin/road noise is from the OEM Michelins?
Be careful with the foam. Had a guy on my Dakota site use it behind the rear seats on the sides of the clubcab, where the rear speakers are. He used too much, and by the time it was done curing, you could see ripples in the sheet metal under the rear windows on the outside.
The OEM Michelins succumbed to nails. Replaced with Potenza RE960s on all 4 corners.
kennungesser: thanks for the tip. I'll try to keep that in mind. Are you saying that the foam actually had enough stiffness to warp the metal?
The Mac
Here is my experience with dynamat. Not really for the rattles, but does give it the luxury car feel. I especially love the way it sounds when I close my doors.
https://acurazine.com/forums/showthread.php?t=37759
Page 3 of the post
Page 3 of the post
Yeah, once you take off the interior panels, there is only a little bit of insulation, then your looking at the back side of the exterior metal. He took out the insulation and filled up the space with the foam, then put the interior panel back on. It warped the metal as hard as it is to believe. He used Great Stuff, and I think that expands to something like 3x. They now make foam that does not expand as much.
there is this stuff called fatmat i think the sit is fatmat.com its pretty cheap.. friend had it and said it was good but he did like 3 layers... they also give u tools to install it and 100 sq ft for 100 bucks.. not bad
Old Man Yelling at Clouds
Page 3 of the post
Page 3 of the post
Foam will absorb the sound, dynamat and the like will block it or deaden the vibrations in panels. Be careful with foam inside the door cavity. The door cavity allows rain water to flow through it, thats what the weep holes at the bottom are for. If you put foam inside the door cavity you're opening yourself up to getting mildew growing in there.
My suggestion is to look up the TSB for door rattles and then apply the foam in the locations where the TSB suggests. Also, it wouldn't hurt, while you have the door panel off, to put a layer of dynamat (or cascade Vmax) on the interior of the entire panel. It will make your car quieter (but may not take care of all the rattles).
The Mac
Originally Posted by 1Louder
T-Mac, couple questions. You removed that white plastic sheet? I've done my door speakers, so I already had the panels off. Was wondering if that stuff was necessary (or what it was even there for). So it looks as if you took off the white, and put the dynamat on. Correct? Second - did you get the noise reduction you were looking for?
instead of dynamat i used sticky tar stickers called peel and seal which is the same as dynamat. i would say it dampens quite well. only about 10 bucks for a roll at lowes.
Page 3 of the post
Page 3 of the post
Your install looks great!!
After seeing your pictures I went ahead and ordered the Overkill
from Second skin too!
The key benefit to deadening your doors is that bass response improves dramatically. Ideally, you'd want to replace the stock weather shield with dynamat, or even plexiglass and seal over all the large holes in the door. Dynamat in itself mostly reduces the rattles in the door from the bass coming from your speaker. You'd need a good constraining layer such as www.secondskinaudio.com or ensolite over that to block road noise.
Even then, it doesn't drive like a Lexus. You'd want to do the floors and around the wheel wells and perhaps even the firewall. In my experience you don't get much noise reduction from the doors, especially using just asphalt or butyl based deadener.
The Mac
MrHeeltoe
20
02-23-2023 01:54 PM
MilanoRedDashR
36
10-14-2022 07:01 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
kixo
09-05-2015 08:54 PM
