Does our radios have an RCA input for the AUX option in the back.
Does the Aux port behind the radio accepts RCA plugs. My MP3 player uses and A/v with RCA connections. I understand I would only be getting sound and would have to controll the mp3 player on the actuall unit.
No, you have to use an AUX audio adapter for that. SNHOND3 or Blitzsafe.
https://acurazine.com/forums/showthread.php?t=3148
Uh, unless you're talking about a 2006 TSX, which has the mini stereo plug built into the armrest storage area.
It helps to let people know *exactly* what car you have, year and all. But there are no RCAs (input at least) to be had on the 'back' of the stereo.
Try checking out the A/V section of the forum, and search this question there.
My bad I have an 04.
No, The 04 Does Not Have Rca Inputs, However If You Have The Non-navi Radio You Can Purchase A Converter That Will Add A Set Of Rca Cable Inputs Using The Aux Cd-changer Input On Your Radio, But You Will Have To Remove The Radio To Install, Which Is Something I Would Rather Not Do Again.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 09:00 PM
