Do you consider this acceptable oil consumption?
I drive 100 miles round trip to work averaging 80-85mph 5 days a week. I usually shift gears around 3-4k rpms and occasionally hit 5-6k rpms. Would you consider 1/2qt every 4,000 miles good/bad/normal under those conditions? Thanks
According to the guidelines for oil consumption that everyone seems to use, 1/2 quart over 4000 miles is low and nothing to worry about.
My personal opinion is different, but opinions don't matter to an automobile manufacturer that provides warranties.
Someone stole "My Garage"
1/2 liter for 4000 miles isn't bad at all -- definitely w/in the normal range.
My car burned 1L/1000km *650 miles* but that was cured with a new short block under warranty.
Keep an eye on it, and as aaronng said, keep it at least above the bottom dot, preferrably at the top dot.
Originally Posted by aaronng
Make sure you top up your oil so that it is ALWAYS above the middle of the 2 dots.
b/c i noticed that if i check my oil right after i turn off my car it isnt at the top dot, but after i check after waiting 30 min. it is at the top dot...
which way should i check it?
Driver/Detailer
Originally Posted by handydandy
are you suppose to check the oil after the car has cooled down (like 30 min. after you turn off your car?), or are you suppose to check oil right after you turn off your car?
IBankMouse
06-13-2020 12:53 PM
joflewbyu2
10-08-2015 11:16 AM
