Cruise Control Minimum Speed/s
Hi everyone
I've had my '04 Accord Euro S (Acura TSX) for four weeks now and am noticing a "problem" with the cruise control.
I am cruising at a steady speed, say 70 km/h, in 4th gear, and turn on the CRUISE MAIN button, but the ACCEL / SET button will not set. Then if I shift up to 5th gear, and press ACCEL / SET it WILL then engage.
This problem then will not repeat itself until the car has been turned off and then on again.
I have searched all over this forum, and google, to find if the Euro (TSX) has a minimum speed / rev speed for each gear under which it won't engage the cruise, but all I can establish is that the owner's manual says it won't work under 40km/h. My dealer was equally as unhelpful.
Help! Any thoughts? Does anyone else experience this same problem?
Thanks,
Steve
Thanks,
Steve
That is actually a pretty good question. I'm clueless.
Edit: I just saw you posted the same thread in Problems & Fixes. No need to start another on here then. Closing.
You can keep posting in the other.
joflewbyu2
10-08-2015 11:16 AM
adreano17
09-29-2015 08:48 AM
4drviper
09-23-2015 09:00 PM
