crooked steering wheel?
When I’m driving on a straight road, going straight, my steering wheel is turned slightly to the right. (the Acura symbol is turned to the right) This really bothers me what do you guys think causes this and can it be fixed?
Automobile Aficionado
Just take it back to the dealer....they should be able to adjust the steering wheel. It is just a simple adjustment i believe. But if you have to constantly turn the wheel to go straight then your alignment is off.
Easy fix if your so inclined...
I used to be a honda tech and did alignments all the time.
You need to adjust your steering tie rod ends....this will place the wheels in the same direction the steering wheel is pointed.
I wont go into details unless you want me to because like some one said earlier, take it in and have it aligned under warranty.
That blowed up real good!
Check the air pressure in your front tires. Whenever the pressure was off in one of the front tires on my Integra it usually threw off the steering wheel a little.
I had this problem too. I never even made it home from the dealership - turned around and made them recenter the steering wheel (took 10 min). So long as your car tracks straight with no hands, its a simple fix.
Re: crooked steering wheel?
The Creator
go get your alignment fixed under warranty.
i have bought 3 new acura's and every single one has been to the dealer more than once in the first 3 months for a fucked up alignment.
its very irritating. but completely fixable.
Originally posted by DEVO
right... if you take off your steering wheel and put it on upside down... no amount of tie rod adjustment will fix this... so the steering wheel can be off by a cog or 2.
Originally posted by Champ
What is your problem and what is your point
my point is that if your car is truly alligned and your steering wheel is still not centered... the problem lies in your steering wheel and not in the tie rods. get it.
so you have to shift the steering wheel over a cog or 2... comprende? i've seen cars that look like they are taking lefts all the time but it was just how they remounted the steering wheel after they took it off for some reason or another.
no problem here.
no problem here.
no problem here.
Have you ever done an alignment before???
Have you ever adjusted a steering wheel with an airbag before???
rockyboy
08-04-2024 10:35 AM
EvilVirus
12-10-2015 07:38 PM
