Clear Corners DIY???
Old Feb 13, 2004 | 12:29 PM
oNetsx2gO's Avatar
Exclamation Clear Corners DIY???
Does anyone , has anyone done or seen where you can clear your front headlight corners??
maybe you can remove the amber part at the corner?
because thats what my friend did to his civic...
help please.
thanks alot.
-paul
Old Feb 13, 2004 | 12:51 PM
xizor's Avatar
Bye TSX, hello domestic?
http://www.acura-tsx.com/forums/search.php?s=
note that your car would not meet DOT requirements if you cleared your lights and hence be illegal. the clears on the Euro-R do look sweet though.
Old Feb 13, 2004 | 12:52 PM
zzzXpandaXzzz's Avatar
Dont imitatate/duplicate!
clear corners
yea i got clear corners for my tsx. They're the Euro R from japan, they cost about 600 bucks dudes, but its worth it for me. No one else has this where i live and there are some tsx's out there. So they have nothing on my TSX. yeahhhh baby... go to sixautoworks.com
Old Feb 13, 2004 | 01:04 PM
xizor's Avatar
you can remove the amber part I believe, much cheaper than the JDM Euro-R lights
Old Aug 5, 2004 | 01:36 AM
SuperAko56's Avatar
Cleared headlights; What do you think?
Hi all, I need some advice. I did the headlight clearing last night.
The housing looks like the way this guy from New York has it in the first pic on this thread:
http://www.acura-tsx.com/forums/show...ght=headlights
It is not an easy task (took my friend and I 4-5 hours), even though I've done it on a CL-S and a TL-S in the past. For the TSX, there is NO reflector inside the housing and the bulb at night shows up as a really bright dot (with a hyperwhite bulb) and almost basically glares at you. I live in LA where cops are known for picking on fixed up rides.
My question is, would it help at all to put an amber bulb inside?
Because we don't want to have to open that housing up again! You have to heat and open and then reseal and heat, plus the time it takes to remove the bumper and each housing. Your replies or ideas would be appreciated.
Old Aug 5, 2004 | 06:15 AM
yuhoo22's Avatar
John Starks - The Dunk
If you put an amber bulb in you should be street legal....at least that is legal in NYC. Should be too much glare on oncoming traffic either with the amber.
Post pics of your ride when you get a chance.
Old Aug 5, 2004 | 07:30 AM
Brooks's Avatar
I had a 99 Civic EX and put some reflective silver tape over the orange reflector inside. It always passed inspection in VA. I think all you have to have is an amber bulb in there. The TSX looks to be different though since the amber reflector is right against the headlight assembly as where in the civic it was set back into the headlight.
hashbrown
Feb 18, 2022 11:20 AM
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
jmaxima03
Sep 27, 2015 10:22 AM
scionxb3003
Sep 22, 2015 05:28 PM
