changing interior dome lights
I was thinking about changing the interior dome lights to white and was wondering what you guys thought of it/your experiences of it.
The thing I know I want to do for sure is swap out my trunk light with a super-bright white bulb, but as for the inside I'm curious if using the super-bright bulbs would be too bright.
Originally Posted by palidanx
how is the blue florescent bulb.. does it look bright? And for the eurolite bulbs, which ones in particular did you get? The hyperwhite?
Originally Posted by slo007
I only have one. Some people put two (one on each side).
I was wondering how did you mount it and connect the power to it? Did you splice the power cable for the trunk light?
hey thats look pretty pimp
Yes, I spliced the cable to the trunk light (you can see in the first pic, the OEM light is off). Make sure that if you do this, to remove the fuse for the lights while you work on it. I burned the fuse on 2 TSXs doing this, as well as my brother's GTI. Those wires come together very easily... after that, you'll need the radio codes to turn the radio back on.
I mounted it using those plastic connectors that people use to hold wires together. I forgot the name... It's tied to the trunk door springs.
mada51589
Jan 9, 2025 04:40 PM
handsom-hustla
Nov 13, 2015 05:04 PM
