center pocket
center pocket
the part that i circle in blue is that suppose to light up cuz i think i might of broke it when i took it apart the other day. does any body have the link to where i can buy it. i look on sunnyside acura and i couldnt find.
Originally Posted by fuckleberry
I say why bother
it's totally & completely 101% useless - just a power drain
I can sell you mine if you want
I would agree.
Besides it is just a very small bulb.
Did you just break the bulb or the connector? If just the bulb, then no biggy. If the connector, I could attempt to look up the part number, but it may be part of a wire loom.
Make a hole, coming thru!
Just curious if anyone found the part number for the bulb? I've got Acura of Peoria looking it up for me, but.... the IPB references a parts sheet B-7 32117, which may be missing from online parts lookups
The light bub burnt out and I was thinking of putting a brighter bulb in there (like the glove box has?) The green filter on the bulb housing[1] may be all I have to take out, the housing's only $7, maybe I'll get out my Big Knife.....
[1] 34770-SEC-003 LIGHT ASSY, CENTER POCKET
The bulb is a #74 wedge-base filament bulb. That's a universal bulb code, not Honda's specific part#. I'm not sure of their part#
The glovebox uses the same exact bulb... no green filter though
I wouldn't add any incand bulb that is stronger since it could burn something (unless you're sure that bulb won't). If you want it brighter, then cutting the green filter out is one easy way... or use a brighter LED since it won't get as hot
mlody
12-04-2019 02:11 PM
InFaMouSLink
10-27-2015 06:52 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
