Break in Style?
#41
Originally Posted by GIBSON6594
what does age have to do with sarcasm?
There was no indication of any sarcasm in your post, sorry, but quotation marks do not signify sarcasm in every sense.
#43
My Garage
Originally Posted by waterrockets
You're not supposed to speak to young children with sarcasm, as they don't understand sarcasm, and take everything literally. "Just great, I wish you wet your bed every night!" will get you a wet bed every night.
So, putting quotes around something absurd, like breaking in electronics doesn't convey sarcasm? Welcome to the internets.
and I didn't even use quotation marks
#45
OMG, your absolutly right, you're so smart...how dare I post in a thread in which you have posted oh master of the interweb...
#46
Originally Posted by JTso
the guy is 36 and still doesn't know what quotation marks are for.
#52
OK, i'll lay off him, but only cause you said so Bond
Dammit, now you've go me going off topic again.
#53
Originally Posted by jlukja
back on topic or
Does anyone have reference to a study that shows break-in method compared to compression loss after 100K (50K? 20K? 200K?) miles with standardized usage for the non-break-in miles?
#54
Someone stole "My Garage"
Ok, so what are the disadvantages of not doing one of the commonly accepted break-in methods? I'm guessing that it would be loss of compression.
For reference, my compression was awesome (very little variance btwn cylinders, and it was about 230-240spsi, I think, across the board). My leakdown numbers were great (not indicative of any problems) at 7% or thereabouts. For 85,000km, that was great.
Turns out it was an improperly-seated/sealing oil control ring causing the burning oil. Compression rings were seated well (hence the good compression and leakdown numbers).
#55
Originally Posted by curls
I don't think there's a true-to-science study of the different methods, BUT, I can assure you that a head mechanic at my dealership said the reason my car was burning oil like crazy was because of a poor, constant-rpm break-in (highway).
#56
IMHO breaking in the engine is essentially a process to avoid unduly stressing engine parts due to heat buildup until they have had a chance to wear in. The heat buildup would be strongest anywhere there is metal-to-metal contact, especially where lubrication is not provided, i.e. piston rings. If excessive heat is generated from friction (and combustion temeperatures) then the metals of the rings, piston, or cylinder wall will bear the brunt of the resulting damage. Most likely of this will be the warping or not proper seating of the rings. The result could include poor compression, loss of power, and excessive oil useage.
#57
IMO, rings are well lubricated, because fo the honing pattern on the cylinder walls. The crosshatch pattern from honing leaves peaks and valleys which trap oil, thus, the rings aren't 100% metal-on-metal. The purpose of the honing is to HELP break-in the rings, by allowing the rings to wear the peaks of the honing down (think of this, vertically, with the flat spot facing the rings: V*V*V*V* )
What this does is still allow for some oil to get into the valleys, and continually lube the rings (past the oil control ring, oil is still present, and this is key!). But, what it also does it not permit too much pressure from getting past the rings from the top down. The ensuing flat spots where there were once peaks help SEAL the rings by providing more contact patch, thus, a better seal, and make it harder for pressure to get past.
By running the engine fairly hard on break-in, the pressures get behind the rings (btwn. piston and ring, in the piston ring groove), and push the ring out towards the wall (ie: expand the ring outward). This helps flatten the peaks from the honing stone, much moreso than just regular la-dee-da driving ever would. If the seal isn't made in the first couple hundred km's, glazing will occur, and the fine honing pattern will essentially be FLAT (thus, NO oil can stay up there, and thus, the rings wear out fast and then you will see some cylinder wall scoring (bad), or blowby because of ring weakness (also bad). Oil also helps seal the rings a bit, too. Think of a suction created when you put a glass down on a wet tabletop... the oil helps prevent combustion gases from getting past and into the crankcase (and is also why a healthy engine will consume a SMALL amount of oil).
#58
I read numbers behind this somewhere but can't find them right now. The difference between the harmful point of the aluminum and alloys in the engine, and the mild heat created from running the engine within the stock systems' specs, is huge. IE: You'd have to severely overheat the engine in the middle of the Mojave Desert to cause enough damage to be noticeable.
#60
Interesting, so it's more of an oil management problem? I guess you're more likely to have problems if you're lower on oil, or from sending burnt oil out the head.
Well, I certainly had RPM variance in my first (reads odometer) 9732 miles.
#61
good posts curls. What I posted was my opinion and this is exactly the type of discussion I was hoping for when I decided not to close this thread.
And waterrockets: Kinda sorta? I'd say its mechanical "mating" to achieve oil control perfection.
#62
AZine doesn't give us gold star stickers to hand out, but you get an "attaboy". The heat buildup I was talking about isn't the temperature of the entire engine but rather the hotsposts generated by high friction wear in isolated parts of the engine.
#63
Just dial 1911
1 Post
This thread is comedy. Everyone is speaking like they designed the K24
Curls, please tell me you're at least a mechanical engineer...I might actually believe part of what you preach.
#66
Just dial 1911
1 Post
Hey, I'm EE. I must have picked up some Mechanical Engineering knowhow by osmosis when I was in school.
#67
However, I do lots of research on my own into this kinda thing (hey, I'm bored at work, often!). Also, I have a few friends who ARE mech. engineers, and they agree with the theories I posted here. Also, head mechanic (10+ yrs. experience) at an Acura dealer also basically said "to hell with the manual, its there to keep the 98% of people who don't know anything about cars, happy".
If you search all over the net and ask anyone, you are gonna find that there are two very discinct people in this world: Those that run the engine in fairly hard, and those that run it in on a casual Sunday drive to church. Oh, and those that don't care, so make it three types of people.
There are hundreds of theories as to how to perfectly run-in an engine, and its like Liberals vs. Conservatives - they never seem to stray at the core.
#68
My Garage
Nope, can't say I am.
#69
Just dial 1911
1 Post
I was just curious about your background...
#71
Why not trust the manual? It seems to me that if cars were grenading at 150,000 due to improper break in - this would be a bad thing for the manufacturer as it relates to dependabilty ratings. Wouldn't they have the best opinon - afterall they did design the build the engine. All the data that I have seen regarding break in is from arm chair quarterbacks, heresay and friends of friends opinons. Just my 2 cents....
#73
Interesting. I agree with the first definition of lugging, for sure. But I disagree with the latter.... Both say that the WOT super-low RPM will likely cause too much pressure and thus a LOT of blowby, increasing the chances of scoring the cylinder wall where the ring gaps are (with the corners of the ring, if that makes sense)...
...I don't think it will hurt in very short bursts, as you mentioned, but I wouldn't recommend doing this over 10-20 second spans... you'll likely be doing more harm than good....
...WOT high RPM gets around this problem because the pressures aren't quite as high (as the cylinder is moving easier and faster, thus, less pressure build-up.
...I think what we all agree on here is that driving it hard (within reason and allowing sufficient cool down and warm up time when appropriate), from the first time you turn the key, is the best way to break in an engine.
#74
You don't have to have designed the k24 to know some things about how engines work. I'm impressed at how much Curls knows for an IT guy!
#75
Honda designed and built the engine, yes. And their goal is to get it to run for 50k miles with no problmes (the warranty period). After that, they don't care too much because they won't have to reimburse dealers for the work (although a company like Honda probably cares more than others). Anything good bad that happens during break-in shows up after this period anyway. Giving people as simple and safe of a break-in explanation as possible in the owner's manual is their path of least resistance.
I am not an armchair QB!
#76
Originally Posted by chrisa04tsx
I think this site has an interesting point which make sense to me. My next car will be broken in this way.
http://www.mototuneusa.com/break_in_secrets.htm
Sorry I'm late on this thread, but that site is total bunk. The truth is you need to follow your manufacturers stated breakin procedure. Why? Because tolerances today are so tight that you can cause engine damage if you drive the piss out of it too soon. Problem with sites like this is they mix some truth with bullshit. So lots of folks take it as gospel when its just flat wrong. Yes hard acceleration pushes the rings out but with tolerances in todays motor this can cause more harm then good. As most of you already know the rings are not fully seated and have not worn in properly. Excessive abuse during the break in period can cause problems not only with the rings but it can cause the rings to scar the cylinder walls. NOT a good thing.
In short FOLLOW the manufacturers recommended procedure.
#77
Originally Posted by ClutchPerformer
<< I'm getting a Ph.D. in mechanical engineering. My research is done HERE (link!).
Oh... wait....
#78
Just dial 1911
1 Post
#79
Ah, so that's where you've been hiding How much longer do you have to go?
Edit: I had to because I was studying for the qualifying exam. But I passed so it's all good now.
#80
They say that the Ph.D. should take 3-4 years after the Masters, but I'm no superstar so I'm expecting 4.
