Bluetooth w/ Blackberry
I find that with my BB 7290 I can receve BT calls no problem, yet when I place a call from the phone it switches BACK to handset and then I have to switch BACK to BT again. Seems like an unecessary step. Is this a HSF issue or a BB issue?
I've seen a similar issue with my 7290 as well, just haven't played with it much at all yet. I think you may have to change the BB Bluetooth settings. I just looked at the Options->Bluetooth on the handheld. You'll see "HandsFreeLink TM", click the scroll button and select Options. By default Discoverable is set to No. Change that to Yes and see if it helps HFL connect automatically. I also went to "Device Properties" and changed "Trusted" to Yes (it was defaulting to No).
I just changed my settings and will check to see if it works in the car tonight (car's at home right now)...
Originally Posted by moda_way
Do this... if it is trusted, once you get paired to the car, then it will use this by default.
If I place the car is dialing this isn't a problem of course, but then I don't have access to my BB address book either.
So what am I doing wrong??
Originally Posted by HollywoodTSX
OK I double checked and have those settings. It's pretty cool that if I'm on the phone when I get to my car it switches to BT. That works great. The problem is when I make a call from the BB, with BT turned on. When I place a call the BT icon is on (showing I'm using BT) then it switches back to handset. I have to click the wheel and select "Activate Handsfree TM" every time.
(I support BBs at my work on the side)
No issues with my 7290 running Cingular's latest software.
I would suggest deleting the pair from the phone, update the software, and repair. Also make sure it is a trusted device after pairing as mentioned above.
I have the 7100 series, so I wonder if it might have something to do with that? What version of the BB software are you running?
MetalGearTypeS
08-29-2016 08:28 PM
InFaMouSLink
10-30-2015 09:43 AM
SUPRMN84
10-07-2015 09:46 PM
