Bluetooth installed and working perfectly
#42
Registered User
Originally Posted by CJams
Can't we all just get along?
Nice install! I like the screen in the "Not An Ashtray!" Where does he dock the cell phone?
#43
VP Electricity
1 Post
If your bro has a problem with me, why am I hearing about it through YOU?
If anyone has an issue with me, I'd be happy to address it directly. But as far as dealing with your comments, I've nothing to do with you.
I just said that I use the external speaker - that's all.
With almost every system design request I get, I recommend two sysems - one with gear you can buy anywhere online or at brick and mortar stores, and the other with gear I sell If your brother feels that all I did was try to sell him somtehting, that's regrettable. Hey, bro, PM me about it, K?
#44
VP Electricity
1 Post
With almost every system design request I get, I recommend two sysems - one with gear you can buy anywhere online or at brick and mortar stores, and the other with gear I sell If your brother feels that all I did was try to sell him something, that's regrettable.
#45
Rep'n Taxbrain.com
All this fuss for a bluetooth install? It's not that hard IMHO.
Eld has helped me numerous times in the past and has never charged me any money. If you ask him the right way, he is very generous with his information and will even go out of his way to help others. I've remember numerous times when he had board members have their installers call him up when they had questions. Read all of the stickies in the audio/video section and then come back and tell me he is greedy and charges for his info.
#46
Registered User
#47
VP Electricity
1 Post
Originally Posted by rbf351
i'm going by what happened with my brother, basically thats it. nothing else to discuss.
My instructions are not worthless... they're just different than how you did it.
You CAN use these instructions to use higher-power relays and use a speaker... but it's not worth the work. I know how... but it's not worth it. It's far easier to install a speaker - especially since retail on the speker from Parrot is like $20 (I make so much money on that it's sick...)
El Guapo, could it be that you are upset about something else, and you are taking it out on me?
Jefe, The Three Amigos
#48
Registered User
i was too lazy to take pics tonight but here is how you wire it up correctly
first remove the navi system and both pockets. First i'll do the speakers
Speakers
take the femle end of the speaker harness from the parrot 3100 and cut the wires from pins 2 and 3 off from the harness. pins 2 are for the passenger side, and 3 is for the driver. 1 and 4 are for the rear and not needed. doesn't seem to matter which is + or - since both ways work
take those 4 wires and goto the car AMP, the harness you are using is connected into the AMP, the connector is light blue in color and has 20 pins/wires
splice into these wires
2 - Passenger + speaker wire (green/yellow)
12 - Passenger - speaker wire (grey/red)
3 - Driver + speaker wire (green/black)
13 - Driver - speaker wire (light green)
Now we need to hook up the power wires
there are a few choice you can either use the radio wires or amp wires
For constant power i used pin 10 on the AMP harness that was used above, it's a white/blue wire
For ground i used pin 20 on the AMP harness that was used above, it's a black wire
For the accessory wire i used the radio's light blue harness which also has 20 wires/pins
what you need to do is find wire 2 which is yellow/red and cut it in half, make sure you leave enough sire on both sides. Now attach the accessory wire to the side of the wire that runs into the car.
now for the relay and mute wire
86 - hook this upto the yellow/red wire you just cut in half on the car side
87a - hook this upto the yellow/red wire you just cut in half on the car side
85 - hook this up to the mute wire from the parrot 3100
30 - hook this up to yellow/red wire you just cut in half on the radio side
what this does is shut the power to the radio whenever the phone rings, or when you use the phone, and lets the amp have full power to work your speakers, and the bluetooth kit sounds perfectlly. if you just mute the radio the sound is very low, and you'll be unhappy with the quality
you can now take any of the leftover wires from the parrot 3100 wires, cut them short and tape them up, they are no use to you.
if anything is unclear please let me know
Speakers
#50
Registered User
Originally Posted by spatel600
You are a joke dude. Aside from that your directions suck ass.
#51
whats the matter too tough for you to follow? trying to insult me, try a little harder than that. anyother fucking moron on this site. go back into your hole and die or whatever
First, your grammar buddy...think you're all smart how about reading what you write. Second, your directions are not organized at all. Too hard for me to follow? Actually I don't need your f-in directions to hook up a simple relay. Anyways I don't want to take this argument any further so I'm ending it there since your ignorance doesn't stop.
#54
Registered User
Originally Posted by glacius
I see a lot of "cut" and "splice", is this process going to void my warranty or are you just splicing wires on the CK3100 harness side of things?
- g
- g
#56
Mic up, Cue, Dissolve 1..
I was hoping some one could help me out with this situation. I am looking for the wire in my 04 TSX with Nav that sends eaither a negative or positive output when the navi voice comes on. I want to use this output to trigger something so when the navi begins to speak the directions it can trigger something and when its done it will revert back. I dont think I am looking for the mute wire but I might be wrong. Basically it is what ever triggers the volume to lower when the navi speaks during routing. I am an installer at Best Buy so i know technical terms if you need to use them. Thank you for your time I am very interested in hearing from you.
#58
Ck3100
I just picked up a CK3100 online. The place I took it to for the install said they'd have to splice into the existing wiring. Is there a harness for an 05 TSX w/ Navi?
The parrot site mentions a part (AC000008AA) that is for all Acura's > 1998. Anyone familiar w/ this?
(My first post, be gentle)
Oakes
Wash & Wax
10-12-2015 11:17 AM
SUPRMN84
09-02-2015 11:50 PM
