Blue Tooth Feature Sucks!
Hi there,
I have had my07 TSX A Spec for a few weeks and I love it. What I don't love is the Blue Tooth feature. I synched my phone up and now I want to disable it but I don't know how. I have never been successful at dialing a number with voice but have to take out my phone and dial manually and then it links to the handsfree. If I am on the phone and I arrive somewhere, I have to hang up before I turn off my car or it will cut the caller off. I can't switch back to my phone. Has anyone else had this problem or should I take it in to the dealer?
Thanks for any insight!
1 Post
why do you have to hang up before you turn the car off?? It should stay on for 30 minutes after the car is turned off.... also have you tried using the 'Transfer' feature?? it switches from HFL to your phone or vice-versa...
If you want to disable it, just go into your phone settings and take off the 'auto' connection to the HFL of your car...
2008 Acura TSX
talk about mudflaps....
Not to be rude or anything, but... RTFM!!!
Bluetooth is an awesome feature in the TSX. The fact that Acura offers it as a standard feature is amazing, especially when other makes like Audi and Lexus keep it on the options list, and some don't offer it at all.
Make a hole, coming thru!
Originally Posted by EuRTSX
![rtfm](https://acurazine.com/forums/images/smilies/rtfm.gif)
OP, also go to www.handsfreelink.com and check if your phone is 100% supported. From description, it's not. If you want to disable the phone in HFL, go "Phone setup," "Delete" (I think). The manual and the quick start guide cover this sheot.
I love how people outwardly say that HFL sucks, while in the same breath admitting that they don't know how to use it. If you don't know how to use it properly, then it's probably not going to work properly.
HFL is awesome. Another cool feature is the ability to send strings of data.
I programmed my office voice mail login and password into the HFL. After dialing into voice mail, I need to tap *81 to login, then my mailbox number#, and finally password#.
In HFL under "Work Login" I saved the string *81 _ _ _ 1234# _ 123456# where "_" is SAY "pause".
To use:
Say "CALL Work Number", "Yes"
Say "SEND Work Login", "Yes"
To make a menu selection say "SEND 1 #(pound)" for example.
To use:
To use:
To use:
Whoa, thats a nice feature, I'm not sure if my Pioneer Avic Z2 Navi's Bluetooth can do that, I'm gonna go read the manual.
Originally Posted by malnik
Yes, I agree bluetooth does suck if you're a retard
![pofl](https://acurazine.com/forums/images/smilies/pofl.gif)
To use:
To use:
Does anyone know how to activate the bluetooth feature in my 2007 TSX for the PalmTreo 700w? Someone stole my car's manual and don't have instructions on how to activate it. I know that I need to press the talk button and wait for the beep sound and speak to it. When I speak, nothing happens. I don't have a navi and is that why? How do I activate without a navi? Thanks.
Originally Posted by davidspalding
Woah...! I never thought about saving a phonebook entry for a post-dialing command string. So you have a phonebook entry called "Work Login" and you can say "Send 'Work Login'" after the AVR answers...? I think you just found another "Easter egg."
I got the idea to enter the entire string because the system says somethig like "say DONE or continue to add numbers." So I thought wtf? ... and kept adding numbers.
I had to play with the pause lengths to get the timing right. Everytime you say pause, its about a 1 sec delay. So you can say "pause pause pause" if you need the data to pause for 3 or 4 secs.
Tip: Because it takes a couple of moments to go thru the command sequence, if your voice mail login has a short window to login like mine does, you need to be quick.
As soon as the phone stops ringing . . . I hear my greeting.
I immediately hit HFL TALK and say "SEND Work Login".
Before system confirms with "SEND Work Login??" - I tap HFL TALK again and say "YES"
The system takes a second and replies "SENDING".
If HFL doesn't say "SENDING" before my greeting ends, the voice mail stops listening for the login and records the incoming call as a voice mail.
I have the pauses set and I've successfully logged in every time I've called now, but it just occurred to me, if I lengthen my greeting, I can lengthen the time I have to login. I bet if I re-record my voice mail greeting, talk a bit slower, and then leave a few seconds of quiet at the end before completing it, that would give a few extra seconds to initiate HFL.
I think Bluetooth was standard on all TSXs w/ or w/o NAVI at least since 2006, maybe 2005.
If you go to acura.com -> TSX -> Features . . . there's a link to the "Acura HFL Mini Website." From the website, this might help:
PalmOne Treo 700w Pairing Instructions: Print | Back
IMPORTANT: You must press and release the HandsFreeLink talk button on the steering wheel and wait for the beep before you speak. This step is required before all spoken commands.
Power on the phone and ensure Bluetooth® is ON. Please refer to your phone's user guide for steps to turn on Bluetooth. Press and release the Talk button on the steering wheel and wait for the "beep" before you speak. Repeat this step before all spoken commands. Say "phone setup" Say "pair" Say any 4 digit PIN code for pairing. Remember it as you will need to enter it into your phone later. HandsFreeLink will now instruct you to begin the pairing process in the phone.
Enter the start menu
With the stylus, select settings
With the stylus, select the connections tab
With the stylus, select Bluetooth to enter the BT menu
With the stylus, check the box to turn BT power ON
With the stylus, select the Devices tab
With the stylus, select "New Partnership..." to begin a new search for pairable devices
Once search is completed, with the stylus, select the device from the list to be paired with and press NEXT
Enter the Passkey and press NEXT
Name the device when asked
Assign a priority if requested
Most BlueTooth systems let you use the features on your phone and you don't need to load them into the car. For a reason that no one can tell me, Honda did not want that system, but the system they have instead. The new TL in 2008 (2009 model), will not require you to load phone numbers into the car.
Oh, and.... Saying "help" after pressing the HFL button will always give you available commands. She (unless you have it configured for a mail voice) is quite helpful, and patient.
Blue Tooth - Thanks
"Yes, I agree bluetooth does suck if you're a retard" Holy smokes. I asked for some assistance and I think I may have received it from a few others but I didn't ask for ignorant comments. Retard is a lovely term. One that's frequently used by children who address my disabled son. Then again, they are only 10.
thanks for taking the time out of your life to post with zero input.
Why do you guys even bother to comment on this board if you're not helping?
Look, its clear that you're not familiar with the ins and outs of the system. Its not the TSXs fault that your phone is not fully supported if that is the case. Its a sad reality that BT implementations vary widely across phones. I've had probably 5 BT phones paired with my TSX, and of them only 1 ever had any issues. Its also not our fault that you haven't READ THE MANUAL. If you had, you would have most of the answers you seek.
It would have helped if you had mentioned what phone you had. That would help other members give you a similar experience, like "I have that phone and it works well, something is wrong in your setup" or conversely, "I have that phone and it doesn't work on mine either, it sucks."
A word to the wise: Keep your personal life and sentiments out of online forums. In an anonymous environment, people are insensitive and no one cares. The only thing that people can reply to is the information you post, so if you make a more robust post or if it was clear that you understand the system, you might have gotten a more helpful answer.
Originally Posted by veevee2007
Hi there,
I just realized another way to accomplish what you want. Delete the pairing in HFL (discussed above), OR ... delete the pairing on your phone. Doing the latter, the HFL will never connect. Problem solved. That isn't in the manual per se, and it might not be obvious if you don't use Bluetooth as much as some of us geeks to (points at himself). Happy new year, and happy driving.
Haha - not really an Easter Egg . . .
MrHeeltoe
20
02-23-2023 01:54 PM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
