bedding new brakes
Yes, you should bed your brakes. I use the 10-0, 20-0, 30-0 and up to 60-0 process. It serves a few purposes...
1. It burns off any superficial components associated to the manufacturing process.
2. It helps to heat up the pads and begin the process of mating them to the brake disc surface.
A piece of advice, drive conservatively for the first week avoiding any sudden/emergency type stops as much as possible.
iVTEC no koe
I've always followed the same instructions as per Hawk Performance's website:
1. After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
2. Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
3. DO NOT DRAG BRAKES!
4. Allow 15 minutes for brake system to cool down.
5. After step 4 your new pads are ready for use.
Originally Posted by loulinjai
where can you find a empty stretch of road to do this safely? in city areas this is pretty difficult
As for the city, i lived in Philadelphia for 5 years for school and had to do it once and ended up down at an empty warehouse with a huge stretch of property behind it by the waterfront. Probably not the safest place to be but its the only thing i could think of......lol
> 100K Mile Club Member
Originally Posted by jlukja
You came to a full and complete stop each time? I understand that, especially with hot brakes, you don't want to come to a complete stop to prevent pad material transfer to the rotors..
Sweet!
Is a hard stop borderline ABS?
I plan on putting in upgraded discs and pads when I need brakes, so this'll be good to know!
So and to your question.
EDIT:
Some say 10mph and my point is, if you are not on the brakes, the pads aren't on the rotor, so you are able to drive through normal streets and bed the brakes. I've bed in 5 sets (2 on my TSX, 1 on my wife's Civic, 1 on a forum member's, and 1 on a neighbors), so I know it works fine. Its all about getting that magical (or not so magical) transfer layer even.
Originally Posted by thunder04
What is considered a moderate stop? 35 to 5 in 4 seconds?
GWEEDOspeedo
01-15-2016 10:39 PM
