Automatic Transmission Fluid Change
Same here 30k Honda 3qts ATF fluid. Drain and fill. You might want to get this tool to make removing the plastic clips a little easier.
Also get some generic plastic clips off Ebay as these clips are cheap and break easily.
Best to stick with Honda ATF, there's alot of multi vehicle stuff but OEM is best way to go and just as everyone said Honda/Acura transmissions are drain and fills only, unless your doing it yourself, if anyone says that you have to flush it, that's wrong, Honda auto transmissions are similar to a manual transmission, rather than a normal A/T and Honda even doesn't recommend flushing their transmissions.
mada51589
Jan 9, 2025 04:40 PM
nanos
Nov 12, 2015 08:41 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
