automatic transmission fluid change
Old 09-21-2006, 09:50 AM
honk not beep
palidanx's Avatar
My car is about at 30,000k and I'm probably going to change my automatic transmission fluid. What kind of auto tf do you guys recommend? And also should I be changing my transmission fluid at 30k or at a later date?
Old 09-21-2006, 09:58 AM
アコードタイプSとくれば、喜びもひとし お。思わず投
lito's Avatar
for a second there I thought you were converting your auto to manual
Old 09-21-2006, 12:24 PM
Tigerriot's Avatar
So did I.
Old 09-21-2006, 12:25 PM
miner's Avatar
The early sportshift Honda trannys ( my '99 Prelude) were notorious for failing due to clogged solenoid screens. I changed the fluid every 15000 (drain & fill - not complete drain). Tranny still needed replacing @ 78000 (Honda replaced for labor charge only). I would change every 15000 and use Honda ATF just to cover you arse in case problems down the road arise.
Old 09-21-2006, 12:30 PM
Rep'n Taxbrain.com
Tsx536's Avatar
When are we suppose to change the Tranny fluid? I thought it was every 60K?
Old 09-21-2006, 12:31 PM
EuRTSX's Avatar
Your thread title is misleading =/
Old 09-21-2006, 12:51 PM
JTso's Avatar
Fixed thread title to avoid confusion.
Old 09-21-2006, 01:15 PM
New to Modding Cars
KapVu's Avatar
I just got to 30K on my 04 TSX. I would like to know when the TF is needed to be changed too.
Old 09-21-2006, 03:00 PM
A DiRTBAG decal on my
TSX2345's Avatar
For piece of mind you can always do it sooner. Much like oil or any other fluid that breaks down over time.
I am anal, I do a all my fluids flush/change yearly. I know it's overkill. Pay a little now or alot later. Preventative maintenance can't hurt
Old 09-21-2006, 05:14 PM
honk not beep
palidanx's Avatar
haha.. sorry for the deceiving title guys.. any other transmission fluid recommendations besides honda atf?
Old 09-21-2006, 08:14 PM
Got Milk???
kaikai114's Avatar
I did my AT trans fluid change just few months ago, was gonna go with synthetic, then decided to stick with Honda advised AT fluid. Did a research, and some people say the Honda transmission is pretty picky on the lubricant fluid. Just to be safe then sorry to stick with Honda AT fluid. Like engine oil, it's the change interval that matters the most instead of what type of fluid.
KC
Old 09-21-2006, 09:38 PM
Driver/Detailer
aaronng's Avatar
For ATF, stick to Honda ATF. I've read experiences of people having a shudder when shifting when using other brands of ATF in Honda auto trannies.
I'd change it every 2 years, or whenever there is a heavy flood and you drove through it. For some reason, hot AT case + cold water = pressure drop in case which leads to a little water being sucked in. It shouldn't be the case, but immediately after a flood, our Accord's AT shifts become jerky. A change in ATF solves the problem.
Old 09-21-2006, 11:47 PM
honk not beep
palidanx's Avatar
where is the best place to get the honda atf? Can we get it at a place besides a dealership?
Old 09-23-2006, 03:51 AM
Got Milk???
kaikai114's Avatar
I just grab them at the stealership, $8-9 bux each i believe
Old 09-23-2006, 07:29 AM
no0bIe
kboosman00's Avatar
How many bottles does the tranny require?
Old 09-23-2006, 10:16 AM
jlukja's Avatar
Acura of Escondido sells Honda ATF through their e-bay store. I've bought stuff from them before (sway bar, icebox) and I found them very good to deal with.
Old 09-23-2006, 12:00 PM
gsrthomas's Avatar
Yes always stick to Honda Transmission Fluid.
Change it every 15k miles, chaning the fluid is easier than doing an oil change. There is only a drain plug, just unscrew that have the fluid drain and fill using the fill hole on top of the tranny. Couldnt be easier. Be advised this is not a complete flush because there is still 1/4+ fluid inside the tranny, but if you change your tranny fluid regularly you will be okay.
Does Honda have one type of Auto Tranny fluid?? I know for Toyota they have two types of Auto Tranny Fluid. I have a Toyota Highlander and it requires Toyota Type IV Auto tranny fluid. There is also a regular Toyota Dextron fluid for older Toyotas.. I have been told that this is a type of synthetic fluid that Toyota makes. All the newer Toyota's use this tranny fluid. I dont know if Honda has just one type or different types of fluids.
Old 09-23-2006, 01:08 PM
She said: it's GINORMOUS!
mg7726's Avatar
3 bottles. i changed at 30k and fluid was brown (red is original)
Old 09-23-2006, 08:43 PM
honk not beep
palidanx's Avatar
sorry for asking yet another stupid question.. where exactly is the drain bolt for the transmission fluid?
Old 09-24-2006, 06:00 AM
Driver/Detailer
aaronng's Avatar
Remove the driver's side wheel. The bolt should require a 3/8" drive. Just use a 3/8" ratchet. Replace the washer if necessary (I always do)
Old 09-24-2006, 02:15 PM
no0bIe
kboosman00's Avatar
Great Description man, ty!
Old 09-26-2006, 04:28 PM
gfd1182's Avatar
is there a dipstick so you know how much fluid to add?
Old 09-26-2006, 04:33 PM
Vegito's Avatar
Dont you need to remove that undercarriage cover ? I mean I had to , thats blocking access to the drain bolt
Old 09-26-2006, 04:59 PM
TSX2345's Avatar
AT = Yes
MT = No
Old 09-26-2006, 11:58 PM
gfd1182's Avatar
Is that true?
Old 09-27-2006, 01:01 AM
acura_ak's Avatar
i have a question regarding the addition of fluid......i'm not too familiar with the automatic transmission vehicles as i have done the transmission fluid change for my previous manual transmission car. i know in the manual transmission you add the fluid through another bolt on the transmission, but how about the automatic? is there a bolt on the tranny or do i simply add the fluid through the dipstick? thanks for any help.
Old 09-27-2006, 02:59 AM
Driver/Detailer
aaronng's Avatar
Add fluid through the AT dipstick hole.
Old 09-27-2006, 07:51 AM
gfd1182's Avatar
does the undercarriage have to be removed or is the bolt accessible when you take the wheel off?
Old 09-27-2006, 08:56 AM
mg7726's Avatar
you can also get a air pump and suck it out via the dipstick.
those that connect to the air compressor, it's really quick too, then you do not have to mess with the bolts, wheel, or crush washer replacement.
Old 09-27-2006, 09:12 AM
gsrthomas's Avatar
This is not a good way of doing a auto tranny fluid change. When you unscrew the drain bolt from the tranny, that bolt is magnetized and will have a lot of tiny metal fragments attached to it. So when you unscrew that bolt you have to wipe off any metal fragments attached to it.
So, doing your method is a big no no.
Old 09-27-2006, 09:22 AM
mg7726's Avatar
i was giving options, there ARE some people who will do it this way
Old 09-27-2006, 11:33 AM
Driver/Detailer
aaronng's Avatar
The bolt is accessible. But, the fluid flows down to the undertray if you don't remove the driver's side plastic clips holding the undertray. I would just pull off one side, so that the tray is not in the path of the ATF. No point taking the whole tray off.
Old 09-27-2006, 04:46 PM
gfd1182's Avatar
thanx
Old 09-27-2006, 06:55 PM
kaliraver69's Avatar
Anyone got a pix of this bolt?
Old 09-27-2006, 07:51 PM
gfd1182's Avatar
some images would be great
Old 09-27-2006, 08:59 PM
Driver/Detailer
aaronng's Avatar
Go pull off your wheel, take a photo of the transmission case and post it up so we can point out which bolt it is.
Old 09-28-2006, 01:17 AM
acura_ak's Avatar
thanks
Old 09-28-2006, 07:08 AM
Driver/Detailer
aaronng's Avatar
Originally Posted by acura_ak
thanks
Forgot to add, use a funnel with a long tube.
Old 09-28-2006, 09:21 AM
John Starks - The Dunk
yuhoo22's Avatar
I looked at the maintenance schedule, but didn't see where it actually recommends you change the ATF. Is it really 60k?
Originally Posted by TSX2345
AT = Yes
MT = No
How come the MT doesn't have a dispstick?
Old 09-28-2006, 12:38 PM
Vegito's Avatar
On my 05, i had to remove the wheel, remove part of the cover so i can slide a pan in there.. the drain is in the middle of the car facing in, not out towards the wheel..
UNLESS there is another drain plug somewhere else and what I been draining is actually not Honda ATF
highly unlikely.. own honda/acura since 99.. kinda hate the cover..
Ill be doing mine again soon... so if someone else has a pic.. go ahead.. or wait till i do mine..
Quick Reply: automatic transmission fluid change
