Auto Transmission fluid change
Old 01-17-2009, 05:04 PM
SoCalTSX
ggarding's Avatar
The owners manual says that the first automatic transmission fluid change is to be done at 120,000 miles. Should it not be done sooner?
Old 01-18-2009, 01:31 AM
R.Tosh's Avatar
I just did mine at 120,000 kms.. Are you sure its not in kilometers? I wouldnt go 120k miles without a change. Every 30,000kms is ideal for me.
Old 03-24-2009, 06:47 PM
aZnTSX's Avatar
HI I just did mine today at 70k, I also had to fixed axle seals leak too..cost me $309 total, for transmission fluid, tire rotation and seal leak repair..I'm now broke
Old 03-24-2009, 06:59 PM
bukxanger's Avatar
i just changed mind at 30k.. it was brownish.. but it feels alot smoother now
Old 03-24-2009, 07:17 PM
Unregistered User
valeratj's Avatar
I changed mine ~2 weeks ago at 31 000 miles. It was brownish too
Old 03-24-2009, 08:37 PM
aZnTSX's Avatar
I do oil change every 5,000 miles....
Old 03-24-2009, 09:40 PM
carmagnut's Avatar
Was it done by a dealership or a private shop? What fluid did they use? I have 51K on the 06 beast and have never once even thought to change the fluid. I really have to get better with some of this maintanance.
Old 03-25-2009, 02:17 AM
ck123's Avatar
did you just do 1 drain and refill? how many quarts?
Old 03-25-2009, 02:58 AM
jl1080's Avatar
I did mine last week @ 36k miles. Just a drain and refill, probably do a flush at 60k.
Old 03-25-2009, 03:25 AM
Need more room in
wong05tsx's Avatar
did a drain and fill at 60k... shit was dark and nasty.... i'd prolly do it sooner if i were you.
i'mma do it again at 80k
Old 03-25-2009, 03:43 AM
jl1080's Avatar
^ aye, mine was already quite dark at 30k
Old 03-25-2009, 03:49 AM
jl1080's Avatar
^ meant 36k...
Old 03-25-2009, 08:03 AM
aZnTSX's Avatar
I did mine at Honda dealer, Honda/Acura use the same fluids type as its stated in the manual. That was my first Transmission fluid change at 70K mileage and the technician said the fluid was dark. lol I totally forgot to change it since i bought it used.
If you didn't do it, get it done. Change the transmission fluid every 30K.
Remember for all fluids and oil, Honda/Acura are the same. For the PARTS, they ARE NOT...
Old 03-25-2009, 09:47 AM
carmagnut's Avatar
Thanks. Would you recommmend a drain and fill atthis point or a flush given my mileage (51K) and the fact that I have done nothing yet?
Old 03-25-2009, 10:46 AM
mduthappa's Avatar
it would good to change it. I did it at 45K and for the long run its good. Its more like a preventive maintence.
Old 03-25-2009, 12:23 PM
where is my garage?!
xjohnkdoex's Avatar
hmm...this thread makes me want to change my tranny fluid now. but i'm not even at 15K yet.
but i will keep it mind when i reach the 30K mark.
Old 03-25-2009, 02:40 PM
aZnTSX's Avatar
Yes you're at 51k already, definitely drain and refill it. It is recommended to be changed at every 30K..By the way, Honda and Acura charge the same rates for their labor. I just found it out when i run around, not a bad idea ..
Old 03-25-2009, 02:42 PM
aZnTSX's Avatar
You are okay, do keep your transmission clean like your engine. They both use oil to lubricate the engine components and transmission gears.
Old 03-25-2009, 09:05 PM
atltsx's Avatar
Just changed mine at 29.5k. Only did a single fluid change (and made a mess of the garage floor).
Old 03-25-2009, 09:16 PM
ck123's Avatar
how many quarts is required in a flush?
Old 03-25-2009, 11:20 PM
waldo98's Avatar
I recently did the auto transmission fluid change around 38k miles. Its a pretty simple drain and fill procedure that I did myself and used about 3 quarts of Honda ATF.
Old 03-26-2009, 09:11 AM
Make a hole, coming thru!
davidspalding's Avatar
I read in another thread that the Acura method is a drain/refill/drive cycle 3 times. Sounds expensive. I'm going to have my next oil change and transmission fluid change at a dealer, either Honda or Acura. I guess my credit card balances are too low...
Old 03-26-2009, 10:08 AM
Old Guy
Simba91102's Avatar
I'm surprised you're the first (in this thread anyway) that I saw to mention the drain/refill/drive 3 times method. I would have assumed it's fairly common knowledge here (it's been around for a long time), but since it evidently isn't, it's the method Honda and Accura uses, and the only way to get most (which is all you're gonna get) of the fluid changed. Also, be careful on the flush thing. Honda/Acura uses a proprietary method I think. You may want to do a search, there's been allot written about it here. If I remember correctly, some flush methods can damage the transmission. And on the change intervals, I think you'd find that every 60K seems to be the consensus figure (more often is basically a feel good measure)(although as mentioned in the thread I think, my 05 maintenance manual specifies a change at 120K).
joarby2 (10-04-2020)
cobra10363
07-23-2024 04:13 PM
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
Mike Bertram
09-10-2015 09:27 AM
quake97
08-30-2015 07:57 PM
Quick Reply: Auto Transmission fluid change
