Am I Normal or Severe?
According to the manual (and Justinsw) severe driving is defined as:
5 days a week I drive route 1 to work and back which is 25 miles at about 1-2 hours. This is 90% of my driving. Would you consider this extensive idling or stop-and-go driving?
Severe
Follow the "severe" schedule only if you drive in one or more of these conditions most of the time:
* Trips of less than 5 miles (less than 10 in freezing weather)
* Extremely hot weather (over 90 degrees F)
* Extensive idling or stop-and-go driving
* Trailer towing, car-top carrier, or mountain driving
* Muddy, dusty, or de-iced roads
My perspective is that, except for a very small minority of drivers, most of us should think of ourselves as "severe." Not many of us get up in the morning and drive 45 minutes, without traffic in optimal weather.
Originally Posted by wsklar
Ok, I have about 5K and it is going in tomorrow for the windshield noise. I will put in for an oil change. Thanks.
Originally Posted by tehCOW
oh and if i were you, i'd never wait 10k for an oil change as stated by the owner's guide. 5k and 3k are the most popular intervals for oil changes.
Ok, so, now I'm confused....I want to keep my TSX for a long time, and 5k (described in manual as interval for oil for "severe" conditions as noted), seems very reasonable. 3k may be the traditional interval for keeping one's car in tiptop shape, but is it necessary for our TSX?
Thanks,
Steven
Thanks,
Steven
, i do it every 3.5 k miles .
wsklar, sounds like you drive in fairly "severe" conditions. 5k would be the average or on the safe side. i drive between normal and severe, so i change mine every 6k or so. maybe after 100k i will change it a little more frequently. honestly, i don't think our tsx, or any new acura needs an oil change within 5k miles.
but i guess people just want to be extra careful.
my brother gets his changed in a '00 tl after every 5k, but he drives in really severe conditions. so far, after 75k with regular maintenance, he hasn't had any issues. waiting to see what it looks like at 100k.
but i guess people just want to be extra careful. my brother gets his changed in a '00 tl after every 5k, but he drives in really severe conditions. so far, after 75k with regular maintenance, he hasn't had any issues. waiting to see what it looks like at 100k.
The every 3 k thing is what jiffy lube and places like that want to believe. With today's engines and high quality oils, every 5,000 to 6,000 is fine for most drivers (after break in).
One of the better ways to time the oil change interval is the BMW way - amount of fuel burned (I think theirs is around 600gal). Then it doesn't matter if its used a little on the highway but a lot of miles or a lot in a few city miles- it's the same amount of wear/use. Time should also be a consideration. Even if you only drive 5K miles per year, change the oil after about 6 mos.
~ Steven
With higher performance engines like ours, most seem to recommend 5-7.5K as the interval.
Only reason I'd worry about changing at lesss than 5K would be in a turbo. Even then, most don't seem to have the problems they used to.
For lower-use drivers there is still some validity to doing it at least every six months.
Originally Posted by majormojo
Yes, the BMW system is very smart. In addition to fuel consumed it also monitors things like the number of times the engine has been started, how often it came up to "normal" operating temp, elapsed time since the last service indicator reset, etc. C&D had a good article about this a while back.
The chosen number is sometimes arrived at with other than just engineering input. I can't see how in the case of MB one year the light comes on at around 15K miles (04 and earlier) and the next it's just 10K (05 and on when the free maint went away).
The only issue is that it's still up to some guy at BMW to pick some number at which to turn on the maint light.
This is a rather interesting topic. I also own an 04 accord LX. I did not buy it from the dealer near my house because for some reason, they wouldn't budge much on the price. Anyways... so at the stealer i bought my car from, their service interval says 3000 miles for the oil change. However, since this place isn't near my house; I cannot go there everytime because i'm sometimes busy. So i go to the stealer thats near me to get the oil change since they charge the same and it's closer. Their service interval is 5000 miles! They are both using the same grade oil and both are using quaker state. So... just goes to show you some dealers/ oil change places will tell you to come back at a certain mileage for more repeat business i guess. But after further doing research, even if you are running on regular old nonsynthetic/ dino juice. You are changing your oil too early if you do it at 3000 miles. It can actually easily go to 5000 miles.
Originally Posted by VeniceBeachTSX
What does the Accord manual say? Ignore all dealers and others who make money off unnecessary maintenance.
Just follow the manual and don't let the service rep talk you into unnecessary services.
Oil change mileage
I just traded my 95 Maxima for a TSX. From 5k on I changed to oil and filter at 10 K with Mobil 1. The car had 170,000 miles on it when traded and burned only 1/8 of a quart between changes, usually at the end of the 10K interval. Only things done to the engine were plugs belts and hoses. Slight lifter tick on start-up after about 100K that lasted a second or two, helped with Marvel Mistery Oil that almost eliminated the problem. Ran like a top, and I would bet the compression was within specs even though I didn't do one before I traded. When the engine was running you could not tell except for the sound, no vibrations. Will keep the same interval with the TSX
5k for me - I ignore my dealer's window sticker propaganda
Originally Posted by jcg878
Meh, I'll assume Acura knows more about when to change oil on TSXs than Larry Hall, MSN, and AAA.
to answer the title, is anyone on this site "normal"?
Double meh! I change the oil in my Accord every 5000mi. I use Castrol syntec my oil still looks like honey when I drain it. I know it could go further. Todays oils and filters are awesome. Not to mention Honda engines are built like none other, why the h3ll would I change the oil at 3000mi when it still is nearly new in the car?
The TSX will get the same, my dealer doesn't even want to see me until the 5k period.
A friend of mine is a service tech at a honda dealer and he said server is if you do mainly city driving, and the temperate goes below 30 and over 90 degrees. I'd say you are server because of your city driving and because the temps do go below 30 and over 90 in NJ.
