Air cleaner & pollen filter replacement...
I just went to the dealer for the 30K service and they wanted almost $200 to replace both filters, oil change & filter and rotate the tires..... so frustrating that it costs so much.
It looks like I can get both filters (pollen and air cleaner) for $63.44 (shipping incl) from acuraparts247.com
It will take less than an hour to replace both right?!?
Changing both filters shouldnt be a problem and not worth the dealer charges! the pollen filter is located behind the glove-box. If you look it up in your owners manual is shows you how to take it out.
Have any of you guys had any problems with using Wix's filters??
We have a mid-west parts chain, O'Reilly's, I can get the air cleaner for $14 and the cabin filter for $16....
She said: it's GINORMOUS!
i believe the 04 4-cyl honda accords use the same air filter and pollen filter. it is much cheaper then thru acura. i got mine thru honda stealership...check them out; do not go thru the dealership this is so easy to DIY.
rcs86
08-02-2016 06:52 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
