Acura TSX(Honda Accord) - trunk leaking problem
Hello everybody
Just to represent myself.My name is Kresimir, I live in Croatia(Zagreb-capital) and own Honda Accord 2006 (know also as Acura TSX for your market).
As mentioned in title I have problem with water in trunk.This problem I noticed beginning of the year.Just won't to check spare tire and realize that have about 1 liter of water.Normaly when car is parked and raining there is no water leaking, only when car is moving.
I suppose that has to do with some air vortex under the rear bumper or similar.
Also I found water behind "fabric" (I don't know tech expression on English).
Only that I knows that water is first collects in this U profile
and when reach one level drains to left (to the spare tire) and right (behind fabric to right outer surface).
I try to splash with hose and mini-wash and only noticed two water drops that leaks under plastic plug inside U profile after 10mins of splashing.
Do you have any idea what to check or similar case.I was suspect to rear lamp gasket but that U profile sheet is separated (welded on) from lamp sheet.
Sorry for bad English.
BR
Kreso
BR
Kreso
Hi
Problem solved.
After few times of driving on wet road there is no any leakage of water.So my conclusion is that was problem on right plug (which is prepared for parking sensor wire).Plug is sealed with sealing grease.
BR
Problem solved.
BR
Soul_Deamon
11-13-2018 04:44 PM
