2007 TSX will not start
My TSX, manual transmission, died on me while driving. Motor will turn over.
Towed it home, tried to read codes and my reader said "no connection with ECU". Tried a different code reader and same issue.
Checked fuses, all good. Checked intake manifold ground, good. Checked power to ECU, good.
Immobilizer light comes on and flashes. Tried a different key, same issue.
Also when ignition is turned on I get "Check TPMS" and "Check emission system"
Removed ECU and inspected for corrosion. Looks clean.
Any ideas?
Bad ECU, TPMS module, immobilizer module?
Thanks,
Russ
Any ideas?
Thanks,
Russ
Possibly a failing ignition switch. Engine shut-down while driving is one symptom.
Easy to replace. It piggy-backs the key cylinder in under the steering column cover.
Item 8: https://www.acurapartsforless.com/v-...ination-switch
It should also be available at local auto part stores.
I had to replace switches in my 1999 Acura TL and 2004 Accord
Steve4748
44
01-01-2023 03:10 PM
HEcreated487
03-04-2010 11:13 AM
