2007 TSX Homelink MasterLift 8160W
Old 10-06-2018, 01:54 PM
ran-d2007tsx's Avatar
Has anyone successfully programmed their Homelink with a Masterlift 8160W garage door opener? How?
Old 10-14-2018, 07:51 AM
mrgold35
mrgold35's Avatar
Received 1,530 Likes on 1,193 Posts
Have you checked out the homelink website and used those instructions? Put in your make/model/year of car and make/model of garage door opener for instructions. If your garage door isn't listed; most likely, an opener within the same family will have the same linking instructions. Following the Homelink instructions and using the Genie Pro Stealth garage door opener to assist in programming was the only way I could ever get my homelink to work.
Homelink: https://www.homelink.com/home/welcome
Side Note: The only issue I have with Homelink is the buttons are always active. If you park outside, someone can break a window and open your garage door anytime. I always park my car in the garage because of that reason. If you can't park in your garage, you might look to get a key chain FOB garage door opener you can take with you.
MemphisAcuraTL
02-12-2018 09:14 PM
1995hoo
12-29-2013 05:39 PM
Dzemaitis
12-09-2009 12:46 AM
Quick Reply: 2007 TSX Homelink MasterLift 8160W
