2006 ETM question
'06 TSX 6MT
2006 ETM question
Does someone have the ETM for the '06? If so, could you please check the diagram for the under-dash fuse block and post what the spare fuses connect to (switched/constant/etc)? Also are all the switched fuses supplied by the same source, or are there different supplies for the different loads?
TIA
TIA
Spare fuses are not connected to any power source. They are spare replacements in case you need to replace one of the "active" fuses. If you remove one, you'll see there are no terminals in the fuse box in the "spare fuse" locations as I recall.
'06 TSX 6MT
i guess i should have been more clear- there are 4 empty slots on the fuse block, and there are terminals in them so i think they're connected to something, and i want to know what.
It would be helpful if you could tell me what the numbers are.
Per Alldata, blank spots are 3 (only US, DRL), 12, 29, 31, 33 (Option Connector). In a diagram, they simply say Not Used. Some may be extra spots for wiring OEM accessories like iVES, etc. The bigger question is which are ignition and constants. The diagrams I have do not speak to it.
A little late, and juding by the info within it, its not going to be a help to you, but here it is anyway.
http://img217.imageshack.us/img217/1520/AcuraTSX181.jpg
http://img217.imageshack.us/img217/484/AcuraTSX182.jpg
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
