2004 TSX transmission problem
Old 11-26-2015 | 03:15 PM
Rafaelalcala's Avatar
6th Gear
I have a 2004 tsx with 183,000 miles.. it started with a whinning noise 3 weeks ago coming from the transmission then like a week ago it started slipping so I stopped driving it and today when I turned it on vsa, check engine, caution triangle came on along with a flashing green D indicator...any ideas would be helpful I'm planning on taking it to the dealer next week since I don't trust any local mechanics.
Old 11-27-2015 | 02:26 PM
kipsy's Avatar
have you ever done a transmission service on the car ?
Old 11-27-2015 | 02:55 PM
6th Gear
No I have not...what do they do when they do that??
Old 11-27-2015 | 06:08 PM
kipsy's Avatar
a tranny service is usually they drain the tranny, 3 quarts come out usually, and they put 3 its back in and if you do this every 15k it usually changes the fluid every 3 years.
important to use honda at fluid.
Old 11-27-2015 | 06:41 PM
6th Gear
Thanks I will take in to service on monday...
Old 11-27-2015 | 09:36 PM
kbh's Avatar
kbh
Have you had fault codes read?
Old 01-03-2016 | 07:42 PM
cherubino's Avatar
version 2019
Originally Posted by kipsy
...and if you do this every 15k it usually changes the fluid every 3 years.
Per Service Manual: Flush ATF at Year#6 then every 90K/5-yr
Old 01-03-2016 | 08:14 PM
6th Gear
Actually I had my transmission replaced. I took it to a transmission specialist and was told that my torque converter went out due to the fact that I had never replaced my transmission filter and it clogged something inside and there wasn't enough oil going to my torque converter...to have it rebuild they where charging me $3,200 with only 1 year of warranty so I just went with a used one with alot less miles than my car.
Old 01-03-2016 | 10:01 PM
cherubino's Avatar
version 2019
first: AT or MT ?
2nd: mileage ?
Old 01-03-2016 | 10:02 PM
6th Gear
Originally Posted by cherubino
first: AT or MT ?
Automatic
Acura604
2G RDX DIY & FAQ
17
10-17-2022 12:06 AM
carid
Sponsored Sales & Group Buys
07-26-2016 05:34 AM
ericcdong
12-04-2015 04:08 AM
sander
12-02-2015 09:21 PM
charmer37
11-27-2015 11:56 AM
