'07 TSX Power Steering Pump
It's time for me to replace my PS pump, but I'm not sure if I'm willing to shell out $800 for an Acura OEM part. Does anyone know if the '04 to '07 Accord PS pump is a direct fit? I've done a search on the forums, but haven't found a straight answer.
A couple of suggestions before you shell out $800...
why does the ps pump need to be replaced? Is it making a whining noise? If so, check out the current thread on “problems and fixes”. Could be $5 worth of o-rings that need to be replaced. Watch youtube videos for tutorials. Plenty out there.
if the pump casing is leaking fluid, spend $50 worth of OEM o-rings to rebuild the pump yourself if youtube videos give you the confidence or spend $50-$100 on ebay for a used ps pump. Just try to make sure its OEM and the casing looks clean.
go to rockauto.com and find a replacement there for cheaper.
but o rings will usually fix it right up if it's leaking as well. there's rebuild kits where you can rebuild all the internal seals for a lot cheaper as well.
