05 w/o fog light.. what can I install there?
I've heard the OEM fog lights often got cracked by small rocks...
Any better aftermarket fog lights that are more reliable? Or.. can it used for CAI? But wouldn't that geometry capture lots of water??
People with an 05 and w/o fogs usually dremel out that plastic cover. For people like me who have the CT-E Icebox, the snorkel faces forward for direct ram air if that cover was either taken off or dremeled out.
Water? It might depend on what intake you have. With the CT-E, I've driven in fairly heavy rain, and nothing has happened to me, nor do I expect it to happen. With an open filter element, there are things you can put on the filter to guard against that (drycharger, I believe its called).
gistered User
lol... no not really, that fog light area isnt the only way air can get in. if you want to get foglights, then get them. it's not gonna noticeably change the performance of the car if at all.
I figured the only reason for cold-air intakes being built the way they are would be to get that extra airflow from the fog light area. But I guess even with it blocked, it does still captures more air than a short ram intake would huh? Thanks the answer
No room in
The purpose of a cold air intake isn't to capture more air, it's to capture cold air. Engine bay air is much hotter than the air down by the wheel well/fogs. This is especially a problem in warm climates or on hot summer days, the engine bay can get quite hot. An SRI is actually going to have better airflow (typically) because it is a shorter pipe with less bends, but it's also hot air.
oh.. the password one requires wire extensions... yuck. Nevermind, I'll pass.
http://www..com/forums/1st-gen-elect...s-cl9-tsx.html
gistered User
InFaMouSLink
10-27-2015 06:51 PM
09-17-2015 09:01 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
