04-07 ABS/VSA modulators should be recalled- complain to the NHTSA
Old 03-16-2010, 02:46 PM
vinuneuro's Avatar
410,000 Odyssey's and Element's are being recalled because the brakes fail because the VSA/ABS modulators leak air into the system.
http://www.google.com/hostednews/ap/...xFiRwD9EFSEIG3
Acura/Honda has been aware of the exact same problem with the RL, TL and TSX for 2.5 years and all they've done is issue a TSB for our cars. Look at the date on the TSB.
http://www.in.honda.com/Rjanisis/pubs/SB/B07-041.PDF
Old 03-16-2010, 03:06 PM
2006 ASM tsx
vthree's Avatar
hmm interesting, I will have to do this..
Back in 07 when I got into a wreck with a Titan, I was only lowered on an Acura A-Spec suspension... none of my airbags deployed, but my airbag computer showed that it was supposed to...
Old 03-16-2010, 03:34 PM
Mskierki's Avatar
Seriously, what does this have to do with air getting into the brake line via the ABS modulator?
Old 03-16-2010, 04:24 PM
Tangoman's Avatar
+1 I have to ask the same question...
Old 03-16-2010, 07:48 PM
Modding newbie
Itchytoe's Avatar
If you haven't noticed this before reading the TSB, then you don't have the problem. Really, just because there's a TSB doesn't mean there's any need for a recall, or that your vehicle has the problem. TSB's don't tell people that there is a problem with their vehicle, they tell the mechanics that an issue has surfaced more than once and this procedure has been the cause in most of those instances.
Old 03-18-2010, 01:17 PM
2006 ASM tsx
vthree's Avatar
ooooops. wow... i was thinking airbag when i saw abs instead of anti-lock breaking system...
hedzup
1G RL (1996-2004)
06-29-2016 08:07 AM
SUPRMN84
10-07-2015 09:46 PM
Rachel Lu
09-27-2015 09:53 AM
HeloDown
09-08-2015 06:51 PM
Quick Reply: 04-07 ABS/VSA modulators should be recalled- complain to the NHTSA
