Upper Ball Joints with OE style ball joints!!
So I desperately needed upper ball joint replaced on the right side. The only thing offered is =/- 1 degree correction ball joints which are more universal than oem replacement. I didn't want to spend $150+ per upper control arm new just to get them replaced. I almost gave up all hope and did one last search.
ball joints
coni-seal didn't call me back and only sell to dealers.
AUTO EXTRA # AXK90469
was found on ebay.
so I ordered 2 and hoped for the best.
I rented the ball joint separator and honda adapter kit and took it all apart. The old ones came out nicely and the new ones FIT!! took me about 2 hours total to do it all.
I didn't take pics since KaMLung did a very nice writeup replace control arm and only thing different is using the press to just replace ball joints vs replacing the whole arm
ball joints
was found on ebay.
The following 3 users liked this post by memphisraines26:
Can you get a shot of what they look like installed when you get a chance? I just did a search of that part number on eBay and have found three different stock photos of the part from three different sellers. I wonder if they are all the same.
What about this one: http://www.ebay.com/itm/Auto-Extra-M...a#ht_500wt_689
It shows the part number as interchangeable.
what sound it made?
I have already hearing some sort of sound from my right side. I just bought my Camber Anchor bolts from amazon. hopefully that fix it. if not i have spare upper ball joints.
those ball joint are like $25.00 a piece on amazon,whats the warranty
i didn't see those on amazon. but if it's the same part, both are still way cheaper than the whole upper control arm that most just replace. 1 year warranty.
philipsajerk (04-11-2012)
when my upper ball joints went, i just replaced the whole arm because at the time i couldn't find just the ball joint replacements...
i think i may have a spare arm laying around if all it needs is a new ball joint...
I've just put a pair on a couple of weeks ago. The diameter of the balljoints that goes into the opening on control arm are slightly larger than the originals, but they went on just fine with a little effort.
main70072 (01-05-2013)
adreano17
09-29-2015 08:48 AM
