need help: Rotors conversion from 2.5 to 3.2...
Old Mar 17, 2006 | 02:44 PM
Goofy84's Avatar
7th Gear
I was wondering if it's possible to convert the rotors from 4 lug nut to 5 because i seem to find more better looking 5 lug nut rims. how can i do this..is it possible? -B
Old Mar 17, 2006 | 02:52 PM
KaMLuNg's Avatar
well first, let me welcome you to the forums with your first post
to answer your question tho, if you are willing to shell out alot of money to do this conversion it is possible, but IMO it is not worth it...
Old Mar 17, 2006 | 10:05 PM
Goofy84's Avatar
7th Gear
well i used to have a civic and converted tha rear drum disc brake to GSR and it was simple but jus the brake lines was a bitch!!! but since the TL have cliapers it shouldn't be a big of a deal right? LMK
Old Mar 17, 2006 | 10:49 PM
KaMLuNg's Avatar
you may have to end up changing the whole arm... but if i were u, i would keep it 2.5 setup.. there are more options for suspension when you compare 2.5->3.2.... i agree u can find some nice 5 lugs out there.. but i THINK u can fit bigger rims on the 2.5 4 lugs... i don't think it is worth the money... save it for something else...
Old Mar 18, 2006 | 11:12 AM
Goofy84's Avatar
7th Gear
yeah i just been wondering around and saw alot of people saying that 2.5 you can have bigger and wider rims. and 3.2 can't really have that much of bigger rims cuzz it'll scratch or watever..is that right? and why when tha bodies are the same?
Old Mar 18, 2006 | 08:02 PM
c29842984's Avatar
The two versions of the car may look the same but are pretty much completely different cars when you look at the mechanical aspect. There's no point in doing that conversion. You'd be better off just buying a 3.2 if you want the 5-lugs that bad.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
johnpancakes014
Sep 27, 2015 12:58 PM
