Help! Rear Rotors Replacement-No Go
4th Gear
97 TL 2.5 L: With thin REAR rotors and worn shoes at 200K miles I set off to replace both (I have a few brake jobs to my credit on other models in the last 10 yrs). Everything went ok until I tried to push the brake piston back into the caliper (using a c clamp, then a mod reversing a steering wheel puller into a pusher!) with absolutely no luck...it would not budge. Opening the bleed valve and applying (a great deal) of force to the piston did no good either, there is something preventing the backflow of fluid in the brake line. Looking at the service manual i did not find any help. Anyone know the correct way to get the piston retracted so that I can get the amount of clearance i need to fit the caliper assembly over the new rotor and brakes...greatly appreciated Thanks
remove the brake fluid line from the caliper and see if it drips fluid
There can be severe corrossion inside the lines or caliper that block it
How did the wear pattern on the pads and rotors look- was it even across the surfaces
Khmer Pride
thats the only way, bleed , it a two person job.. if it fail you might want a new capilers.
what i do is for a one person job is unbolt the bleed and push the piston all the way down andput my pads in then put my bleed bolt on and press the pedal to the floor with a peice of wood, and then tight up the bleed a lil more, and press breaks again and same procedure one more time. and all set.. good luck though
Sounds bizzare krazzie- I wouldnt put that in the safe methods box
For cincy
You may have a plugged bleeder screw - remove it and inspect for tiny hole going thru
Spray carb cleaner thru it- the bolt that goes thru the brake line may be plugged- it too has a small passageway that should be inspected and cleaned
Available at any parts store 2 bucks or less
Even though you kept up on the brake fluid flush- things wear out in cars
For cincy
Khmer Pride
For cincy
For cincy
大日本帝国
Originally Posted by KrayzieDxC
hey im saying its my way. im not telling no body to do it. my breaks work 100% fine! your choices.also flush my dirty break fuild too.
~Cheers~
Thats why we need to fush the fluid every year- rust!!
I got calipers off Kragen online, 72 fronts 77 rears, and I went with Legend dual piston calipers for the same price for the fronts
You can usually get the store to price match their online store too- just print it out
4th Gear
Update-job well done
finished the rear brake job.... the gory details:
the piston is retracted by screwing it back into the caliper body. u need a special tool that can be used with a socket wrench, the tool fits into the recessed cross pattern on the piston face. be prepared as it takes many turns to screw the piston back into the caliper so that it will clear the new pads and rotor. u can get the tool at any auto parts store or harbor freight for $5 -$10. I bought rotors from a reputable on line parts store that were "OEM After Market" for $62 ea and Performance Friction Brake Carbon- Metallic pads for just over $50. If the pads work as good as they look I'm set. Got 199K miles out out of the rear rotors and 120 K out of dealer the pads!
