Camber kit necessary?
I plan on getting either a shock+spring set or coilovers in the near future the question I have is if I will need a camber kit for the shock+spring or the coilovers? If I get coilovers with a pillow ball mount will this remove the need for a camber kit?
takin care of Business in
Received 4,732 Likes
when you lower you car the tires start pointing inwards (referred to as STANCE)....by doing this your tires will last you probably 15K miles....
i was dropped on tein basic and my falkens lasted me 18K miles....the camber kit makes your rims go back to normal so you are lowered and you do loose the stance but a shitty tire like fuzion lasted me 45K miles....
hope that helps...
hope that helps...
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
