vibration
Old May 24, 2005 | 12:26 PM
nick96acuratl's Avatar
vibration
when i stop at a light with the engine idling i have a vibration on the steering wheel and basically my whole interior is vibrating.. i can feel it on the pedals and on the seat.. its pissing me off.. when i put the car in neutral or park it goes away... im guessing the engine runs a bit rough when it has a load... but when im going 4mp/h and up it goes away.. i havent adjusted my valves yet since i got the car last year and i think thats could be the problem but it could be the engine mounts.. i have checked them few times and they seem fine.. i dont know man. any ideas? also i was told that it could be the torque converter... oh when the engine warms up too it gets better but still u can feel it but when its cold its pretty bad..
Old May 24, 2005 | 05:09 PM
dubcnea's Avatar
Hurricane Game
i know TCCs go out in a lot of chevy 3.1s, but not sure about acuras. oh, tcc is torque converter celenoid in case you didn't know. but if that was bad, then the car would stall on you when you came to a stop after driving for awhile. maybe it acts diff. in acuras, but that's how it is in chevys.
Old Aug 15, 2005 | 01:18 PM
pi1996's Avatar
i have the same problem, did you get to the bottom of it?
i want to check the level of my differential fluid..
Old Aug 15, 2005 | 04:46 PM
bpjadhav's Avatar
1998 2.5TL
I've the same problem. I can feel the vbration in the steering wheel and the pedals. It usually happens at nights when I stop at lights. It can be quite bothersome.
Old Aug 15, 2005 | 10:04 PM
DJRamzy's Avatar
2003 Acura MDX
I never have that problem, I would think its something in your fluids, just my 2 cents.
Old Aug 16, 2005 | 09:04 PM
well i have done a tranny flush... oil changes earlier then recommended and still there is a little vibration.. but for some reason not as bad as before... dont know what to do... im going to adjust my valves maybe in the next few days if it helps ill tell you guys
Old Aug 23, 2005 | 10:05 PM
Ken1997TL's Avatar
Sounds like either engine mounts or a tranny mount.
Old Aug 24, 2005 | 01:55 AM
miltcharlie's Avatar
Lord Ubber
try resetting your ECU.
TAke out the engine compartment fuse for about an hour.
Some say 10min. I do it over nite. But an hour is good.
Maybe it just needs a reboot.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
