Torque Specs?
Old May 20, 2006 | 03:52 PM
Goro_98_2.5's Avatar
Torque Specs?
Does anyone know the torque specifications for the transmission pan and ATF strainer, I was about to clean my tranny screen but realized I wouldn't be able to tighten things correctly
Oh yeah..and the specs for the drain bolt also.
I know this is asking a lot, but I can really use the help.
I only got a book for my VIGOR, which is basically the same car, but it doesn't show anything about these parts.
-thanx
Old May 20, 2006 | 04:46 PM
KaMLuNg's Avatar
it is in my DIY... bolt at 35ft/lbs, and pan at 9 ft/lbs..
https://acurazine.com/forums/showthread.php?t=131434
Old May 20, 2006 | 04:54 PM
TexasHonda's Avatar
Drain plug is 36 ft-lbs w/ new crush washer.
Screen bolts are 8.7 ft-lbs.
Caution! Be sure to keep up w/ bolts and associated hole or get a manual. There are three different bolt lengths.
Transmission pan bolts are also 8.7 ft-lbs.
I would recommend replacing the screen because it's difficult to determine if screen is clean. I bought a new one for around $20.
good luck
Old May 20, 2006 | 05:57 PM
Thanx for the help.......very appreciated!
Lets hope for smoother shifting
Ill let you guys know how it goes when finished
Old May 20, 2006 | 08:06 PM
KaMLuNg's Avatar
texas is right... and get new gaskets also...
Old May 27, 2006 | 05:19 PM
I decided to take your guys advice and just get new everything.........the only thing that sucks is live in Hawaii and the dealerships down here are ridiculous.......the ATF strainer alone is $65 and the pan gasket is $30 ........so I went to OverniteParts and ordered everthing for about $58 including the O-ring........it'll take about a week to get here (not quite overnite..lol), so the job is pending for the moment.
......thanks again for the all the help
08KBP_VA
Oct 22, 2019 01:55 PM
emailnatec
29
Sep 28, 2018 04:27 PM
jsonkimz
Mar 28, 2016 07:49 PM
knight rider
Mar 4, 2016 08:59 AM
Tribalheads
Sep 29, 2015 03:24 PM
