Sudden engine off
Old Apr 4, 2013 | 01:54 PM
Mandy's Avatar
98 3.2 Flamenco Black
Sudden engine off
Has happened to me 3x in the last 3 weeks. It will just lose power and the engine will shut down. I re-start and everything's OK again.
No CEL or MIL.
What could this be an indication of?
Old Apr 4, 2013 | 01:56 PM
Mandy's Avatar
Background:
1, 110K miles
2. No timing belt done yet
3. No CEL
4. Everything seems to run OK
5. Idle is OK
6. Have had a mis-fire 3 weeks ago. 1 time deal.
Any ideas?
Old Apr 4, 2013 | 05:25 PM
7 Tl's Avatar
That's happened to me a couple of times. ignition switch, main relay maybe
Old Apr 5, 2013 | 02:07 AM
jrot's Avatar
failing MAF or equivalent will often act this way. electrical is also possible.
Old Apr 5, 2013 | 02:10 AM
Go90go's Avatar
大日本帝国
Sounds like the main relay's solder joints to me.
~Cheers~
Old Apr 5, 2013 | 12:14 PM
Mandy's Avatar
2 votes for main relay! Where is it and how?
Some of you have repaired this?
Thanks in advance.
Old Apr 5, 2013 | 03:21 PM
jrot's Avatar
is that the one that you have to get at from the pedal area? i think it kinda sits at behind the gauge cluster above the pedals yeah? ill be shocked if thats it though. would be a honda fail....
Old Apr 5, 2013 | 08:47 PM
7 Tl's Avatar
Yes you're right on the location. Just take a flashlight and look for a box that says relay assy. Main relay is right inside
Old Apr 5, 2013 | 11:38 PM
Go90go's Avatar
大日本帝国
It is pretty far up there.
~Cheers~
Old Apr 8, 2013 | 11:42 AM
Mandy's Avatar
And normally waht is the repair? Replace the relay? Thanks.
Old Apr 8, 2013 | 11:43 AM
Mandy's Avatar
Pis anyone?
Old Apr 8, 2013 | 09:34 PM
main70072's Avatar
You can either replace relay if it's bad, or take it apart and re-solder the joints.
Old Apr 10, 2013 | 11:50 AM
Mandy's Avatar
How much is this relay, anybody remember?
Old Apr 27, 2013 | 06:57 PM
SHAKEYTOWN's Avatar
This happened to me couple of times, then it went for good while driving on the i-5 in cali. It's the ignition switch under your steering wheel column, cost's about 45-50 buck's - easy change out, diy
Old Apr 28, 2013 | 03:40 PM
Mandy's Avatar
Any link to the DIY on Ignition Switch link please? It is happening frequently nowadays, starting to piss me off. Thanks.
Old Apr 28, 2013 | 03:41 PM
Mandy's Avatar
What do actually replace? I have read them before but did not pay attention.
Old May 6, 2013 | 09:14 AM
Mandy's Avatar
This is becoming more frequent and it is a potential issue. If I take it to the shop, what do I tell the mechanic? I think it is fuel supply related. Not an ignition nor a main relay issue (??).
It seems that it is running out of fuel. When you re-start, everything is back to normal.
I need ideas...thanks in advance.
Old May 6, 2013 | 09:24 AM
Mandy's Avatar
What is the igniton switch #
Old May 7, 2013 | 05:21 PM
jrot's Avatar
please please check the mass air flow sensor or equivalent. easy fix probly not cheap but it sound EXACTLY like what your issue is in EVERY way!!!!
Old Jun 18, 2013 | 03:03 PM
Mandy's Avatar
This has been resolved with the Main Relay replacement! Knock on wood.
Mandy's Avatar
Old Feb 12, 2014 | 10:33 PM
OLDMNSX's Avatar
7th Gear
Most of my experience is with other Hondas. Ignition switches and main fuel relays are a problem on older high mileage cars. Typically the ignition switch will rear it's ugly head when trying to start and the main relay while it's running. I have disassembled the ignition switches and cleaned the contacts to fix them.
I recommend to most people to purchase a NEW relay unless you are good with a soldiering iron.
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
gator90065
Oct 8, 2015 10:14 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
Phambam12
Sep 6, 2015 06:57 PM
