spark plug tube filled with oil!!
hey guys so i recently replaced my valve cover gasket due to an oil leak. today i checked it and all 4 cylinders in the front were good. the last tube was filled with oil.. bad seal? can i take it apart and re-use the gaskets since they are so new?
so because you had a bad seal, did that mean you had smoke coming out of your exhaust? Did you do it yourself or paid someone? I think I am having the same problem because I am smoking like the spyhunter car smoke screen.
it is very easy to replace. i ordered it online for around $14 shipped. if you see any oil in the tubes its gonna be alot more because you will need the entire kit. it is very easy though i could do it in 15 minutes.
and yes, oil leaking from the valve cover gasket will smoke on the exhaust manifold.
cycdaniel
12-17-2019 10:58 AM
