Radio Code
Old May 19, 2006 | 12:06 PM
jgtl25's Avatar
Radio Code
I Lost The Radio Code Someone Help Plz Where The Hell Is It
Old May 19, 2006 | 01:12 PM
copy252's Avatar
mine was on a piece of masking tape on top of the unit
Old May 19, 2006 | 01:44 PM
UnsanePyro's Avatar
Registered Driver
Some people have found it in the glove box/fuse box, but if you can't find it written there, I made a thread on how to get the serial number, which you will need if you contact the dealer to get the code
Old May 19, 2006 | 06:44 PM
TexasHonda's Avatar
Mine was on a plastic card in the owners manual portfolio.
good luck
Old May 19, 2006 | 06:45 PM
Ken1997TL's Avatar
Others have seen it underneath the coinbox..
Old May 20, 2006 | 01:54 PM
copy252's Avatar
in other words.... its in the car somewhere
Old Nov 1, 2006 | 03:04 PM
theinfamousrobbdeep's Avatar
Hey I haven't seen this answered.... although I am sure it is an obvious one. My deck now is not allowing me to enter the code. How can I reset this to allow me to enter the code?
Thanks!!
Old Nov 1, 2006 | 06:53 PM
TexasHonda's Avatar
Thanks!!
You need to pull the BackUp fuse and reset the radio. After several attempts to enter the code it locks the radio until a reset is done.
good luck
Old Nov 2, 2006 | 09:19 AM
Thank you TexasHonda! Is this BackUp fuse located with all the other fuses or on the connection for the deck?
Old Nov 2, 2006 | 04:52 PM
TexasHonda's Avatar
It's an under the hood, 10A fuse labeled BackUp. Your ECU will also reset so don't plan on an emissions test till you drive for an hour or so.
good luck
Old Nov 23, 2006 | 10:53 PM
OCSHELLY25's Avatar
Help! I Purchased My 1996 Acura Tl 3.2 As A Used Vehicle Without The Owners Manual And My Radio Is Not Working It Displays The Word Code, How And Where Do I Find This So Called Code?
Old Nov 23, 2006 | 11:10 PM
KrayzieDxC's Avatar
Khmer Pride
check inside glove department on the side..should be a white label,might
Old Nov 24, 2006 | 04:20 PM
hoser's Avatar
Why would they even put the Radio Code anti-theft feature on the stock (non-Bose) radio? It's not like it's a premium sound system. The sound out of mine is mediocre at best.
Old Nov 25, 2006 | 11:50 AM
JetBlackAC's Avatar
I just had to replace my battery and needed the code...thank god the previous owner kept the code in the manual...
dirleton
Aug 6, 2024 08:19 PM
Jamus22
Jun 11, 2023 10:08 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
