Question about "Exhaust Manifold Cover"
hello peeps,
I have a 96 2.5 tl and from what i'm told this part is called the "exhaust manifold cover" it came off while i was going over a speed bump ( i guess i went over it little too fast). I went to the dealership and they're askin almost 300$ for this part and its just a piece of metal. I asked around, one person says its important because it prevents the salt thats put on the roads in the winter from reaching the catalytic converter and the rest of the exhaust line. The lady at the parts dept said it aint that important and so have a couple mechanics. But i figure if the manufacturer put it there, it must be fore a reason. My car is in really really really good condition and i want to keep it that way. So what should I do? should i spent the 300$ and get it or leave it the way it is?
leave it til winter atleast, i have my catalytic cover off and my exhaust manifold cover off for work i was doing to it.. dont worry. i got a 97 tl 2.5 but i would not pay $300 maybe 50 ha dont worry
try to pick up a cover from a salvage yard.
try these links:
http://www.car-part.com/
or
http://www.uneedapart.com/index.php
try these links:
or
Str8 Home built
iam working on my exhaust manifold right now and i was going to wrap my exhaust manifold in that heat rap thing they use on headers. beacues the exhast manifold looks like a header in the 2.5 TL. and to put the shiedls back on was going to take alot of extra time to put on. well that was the idea but am puting my sheilds back on if i can and if i cant them am have to use that heat wrap.this is what the exhaust manifold looks like on the 96 TL 2.5. also i dont knoe why they had the first cat welded to the manifold for..?
![](http://i80.photobucket.com/albums/j190/bigworm187_2006/my%20TL/0814081856-00.jpg)
大日本帝国
An exhaust manifold IS a header.
It looks like a pre-cat, not the cat. On CA 3.2s, we had a 36" long cat, and on Other-49 ones, the cat's 33" long.
I agree with k9500: it's not in excellent shape if there are parts falling off.
~Cheers~
~Cheers~
Str8 Home built
Its a really hard job to do. the only heat shield i took off was the one u can see when u open the hood. i took of all of my shields when i had the manifold on the ground. what bolts are you trying to get to...? when my dad and i were removeing my manifold we had to use alot of extentions to get to certan bolts. and i did remove some bolts on the shield when it was still on the car (shield was still on) so i can get to thoes hard to get bolts. how are u takeing it off..? do u got your car on jack stands or a lift..? if its on jack stands the manifold wont come down till u take of the flex pipe. have any more quetions let me noe dude....
it will be at my friends steel company, on a car lift. i was trying to take off the underside shields. where it heads up that narrow passage up to the engine. and i did remove the upper shields accessed through the engine bay. we have all the tools and stuff obviously, but i just didnt wanna try and turn it into a mess. if i just get off all bolts from the engine, disconnect 02 sensor, and unbolt from the front pipe will it just slide down?
Str8 Home built
okay thanks, and im not sure? the car has something wrong with it. i think its exhaust because of the obvious sound sometimes and loss of power at the petal. exhaust leaks just have that feeling ya know ha. and i was gonna probably add a mid-muffler to my stock exhaust, would that help alot? im not very knowledgeble on exhaust setups
Str8 Home built
Str8 Home built
ooh yeah that would be nice to make sum headers ..lol.. yeah if i had a shop i'd try to make some but i dont got the tools to do that. yeah my manifold was cracked in the middle pipe were it turns into 3 pipes and the cat is welded to it. so i juss welded it. how far are u now takeing down that manifold..?
i didnt take off the manifold yet, i do it on the weekend where i have plenty of time. and i have been considering creating headers at the shop using a gasket as a template. but the shop doesnt have cad equipment so it would be hard.
Str8 Home built
i got pics of it on my post project white gurl.. i got it for 100 bucks. i got it for back up in case the one i had on my car was really messed up or broken. but as far as i noe am not goin to use it and the look exatly the same juss a a couple diff thing go check it out...
Str8 Home built
yeah i noe that vigor manifold can be a good start... i went to the dealer ship the other day with my friend and juss for kicks i asked how much is an exahust manifold for a 96 TL 2.5 and the ytold me $1700.. I WAS LIKE DAM........! lolol
Str8 Home built
yeah thats what i ended up doing instead of useing the other one i welded mine and got it over with. but takeing it down is a mission you know. like bolts strip or they minght be realy super tite on ther you know. so if you what your doing go for it other than that take it to a shop.
If you have less than 150,000 miles on your car, take it to an Acura dealership to get it fix for free under the extended emission warranty before taking it apart. You can call Acura at 800-382-2238 and give them your vin# and ask if your car is covered under the extended emission warranty.
i already went to the dealership..they dont do it for 98 and they were gonna charge me 1200 for the part not including labor..I'ma have my brother inlaw take it off and weld it back together
Str8 Home built
Iakonafuji
09-21-2015 02:39 PM
Hau_nguyen91
09-06-2015 12:53 PM
