Power Window Problem.
I got problem going on with my front passenger window. It will only go down. I am having hard time to roll it back up, so I can't leave my car out in parking lot.(I don't work today, thats a good thing I have some time to fix it up). It happened couple of months before too. What is possibly wrong?? Time to buy new switches or some thing else??( Main window control switch<passenger side switch> and the one on passenger window, both only roll the window down)
I am having a similar problem now but with both right side windows. They go down, but sometime won't go back up. It seems more like an electrical problem, but maybe it's the regulators going bad.
I hope someone knows a way to confirm the problem.
Thanks and good luck.
My drivers side window does it too. If you carefully jiggle the windows switch/button as you try to roll it back up it should start to move.
I had a similar issue on my Legend, one possible trick to so take apart the switch and clean it down with some rubbing alcohol to make sure that all the contacts will work right. I would also check for any shorts in the wire while your at it too since nothing is worse than getting a new setup only to find you have to splice and solder a new piece of wire.
I will go ahead and try it, i am also planning to buy a new battery because it looks bad and i had similar electrical problems before which was due to a malfunctioning battery.
I'll see how it goes and post it.
xsilverhawkx
09-28-2015 06:51 PM
rboller
09-23-2015 02:49 PM
