The noises continue... Front driver side grumble...
Old Apr 27, 2010 | 02:47 PM
KaMLuNg's Avatar
so this morning on the way to work, i different type of noise coming from the driver side front area. last week i changed the UCA so the ball joint is new and the clicking is now gone during certain turning positions...
but now, when i was in traffic, i heard this slight grumble/gurgle sound happen if i was slowly creeping and jab the brake pedal really quickly... at first i thought that it was the brake caliper clamping the rotor, but it shouldn't make a grumble sound? and it didn't happen if i had the car in neutral and press on the brake pedal... so it happened only when i was moving at slow speeds and quickly stopping...
any thoughts? everything looked okay when i changed the UCA except the tie rod dust boot was broken, but no noises when turning the wheel... do we have strut bar bushings that go bad?
Old Apr 27, 2010 | 04:11 PM
DUECEON9ER's Avatar
I have the same noise but from the front passenger side I suspect the tie rod end "Ball" wearing out because when I checked the tie rod end "ball' had some play almost felt loose. It sounds almost like it's shifting or something. Anyways good luck figuring that one out.
Old Apr 27, 2010 | 08:47 PM
KaMLuNg's Avatar
i have to agree with you as it seems to only be happening if the wheel is slightly turned...
i'll check that tie rod again since the boot was a bit torn anyway...
it is never ending!!!
Old May 17, 2010 | 06:39 PM
Slpr04UA6's Avatar
-------Tim-------
Did you ever resolve the clicking issue? And how was your tie rod? Do you or anyone else know if the tie-rod should have a little play, or none at all? I am looking for an after market tie rod, if needed? I am unsure about this....Thanks
Old May 17, 2010 | 07:39 PM
DUECEON9ER's Avatar
It's definitely the outer tie rod I just inspected it and the boot was torn. It had alot of play when I took everything apart so that's next on my list.
Old May 17, 2010 | 08:15 PM
desired_speeds's Avatar
are your lug nuts tightened?
csmeance
Jan 7, 2026 06:25 PM
nanos
Nov 12, 2015 08:41 PM
Ny1718
Sep 11, 2015 09:21 AM
JnC
Sep 11, 2015 06:06 AM
08 NBP TL
Sep 8, 2015 08:49 PM
