No turn signals
Old Sep 10, 2009 | 12:52 PM
apz24's Avatar
No turn signals
So on my way to work my turn signals just stop working. I checked the fuse its good, check the bulbs both good. I did notice that the hazards dont work either. Oh ya its not making the clicking noise when you engage them nor is the flashing the arrow light going on in the dash. Anyclues to whats wrong?
Old Sep 12, 2009 | 07:05 AM
TexasHonda's Avatar
Make sure fuse no. 35 (10A) in underhood fuse box, and fuse no 5 (7.5A) in under-dash fuse box is good. The 10A fuse drives emergency flashers and 7.5A drives turn signals.
If both fuses are good, the Turn Signal/Hazard Relay has likely failed. This relay is on the under-dash fuse panel, top LH position. It is also potentially possible for the emergency flashers switch to disable both systems, however this is unlikely since the switch is infrequently used.
good luck
Old Sep 12, 2009 | 10:20 AM
TLin401's Avatar
'13 Hyundai Sonata
Its the relay.
It should cost you like $14 to replace it.
Old Sep 14, 2009 | 11:29 AM
apz24's Avatar
Ok the underhood relay was what i thought had gone bad. I whent to atouzone to pick one up and they wanted to charge me 24 bucks, so now im shopping around for a cheaper one now. Hopefully it fixes the problem
Old Sep 14, 2009 | 11:40 AM
TLin401's Avatar
'13 Hyundai Sonata
Go to a salvage yard and just pull it.
All 1G relays are interchangeable.
TLin401's Avatar
'13 Hyundai Sonata
Old Sep 18, 2009 | 01:51 PM
apz24's Avatar
Is this where the relay is located. I replaced the one that says "small lights" and it blinkers still arent working. Im lost
Old Sep 18, 2009 | 06:43 PM
TexasHonda's Avatar
Read my post. It tells you exactly where the hazard/signal relay is located.
good luck
Old Sep 22, 2009 | 08:39 AM
stas2007's Avatar
good luck
apz24 FAIL lol
Old Sep 22, 2009 | 05:38 PM
apz24's Avatar
I found it thanks man.
stas2007 get a life
Old Jun 18, 2014 | 03:38 PM
SouthFloridaCL's Avatar
Same issue here, now checking, oh & $13 @ Advance Auto parts for the relay.
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Greengecko
Sep 16, 2015 08:19 PM
