- No heat! -
Old May 7, 2010 | 06:54 PM
Nov!ce's Avatar
White Type-S
Question - No heat! -
It's not like I need it right now, but I can't figure it out. A/C blows hard and cold. Temp guage does take a bit to rise, but maybe it's because it's cool in the am. It rises after a while to about 30% of the guage, not half way, but a bit above 1/4. Anyway, when I turn the heat on, cold air comes through. Do I have a cooling problem or is my climate control broken? It adjusts on the cold side (the colder I go the harder/longer it blows).
Old May 7, 2010 | 07:06 PM
bwallace530's Avatar
these cars are full of problems they are old and cost to much to fix now unless you know the right people
my ac/heat turns on and off all the time i have to drive over 80 for it to start blowing or if i park a certain way. I still have not found whats wrong not fuses or relays i was thinking that wire that goes to the heater core but dont want to tear out my whole dash to find the problem
Old May 7, 2010 | 10:19 PM
tmnhs81's Avatar
Do you hear those "gates" in the dash moving around which adjusts hot or cold air?
Old May 9, 2010 | 03:57 PM
I can hear relays or something moving around when i turn the adjuster from hot or cold and when i change where to air will come from like top or bottom. Even when the air is not coming out its like the fan shuts on and off when it wants to.
Old May 20, 2010 | 11:48 AM
Drebotja's Avatar
3rd Gear
i hear ya
Old May 21, 2010 | 04:23 PM
Nov!ce's Avatar
White Type-S
I'll check. I think that I do, though.
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
