here we go again!!
Old May 17, 2010 | 06:08 PM
7 Tl's Avatar
here we go again!!
so i got my valve covers replaced both sides. drive the car back home from the shop, open the hood..and smoke is still coming from the left side of the engine block. Not as much as before but still......what can be causing this bullS***?? did the shop not fix the problem or whaT???
Old May 17, 2010 | 06:10 PM
JZDX's Avatar
It may be just left over oil on the block .. I would clean it or take it for a nice long ride and then check it out after.
Hope its all ok !!
Old May 17, 2010 | 06:18 PM
7 Tl's Avatar
i did drive it for say , maybe 10 mins and left the car running for another ten but still it smokes.
Old May 17, 2010 | 08:13 PM
desired_speeds's Avatar
bring it back and make them fix it correctly.
Old May 17, 2010 | 09:57 PM
DUECEON9ER's Avatar
Need to drive it way longer than that have you personally seen the build up it can cause over so much time
Old May 19, 2010 | 02:28 PM
7 Tl's Avatar
^ hmmm , if there would be a lot of oil build up im pretty sure the more i drive it or have the car on would diminish the amount of white smoke that is coming out. Yet the amount is constant .."not too much" but it's still there you knoww.
