HELP AC Problems
Old Aug 2, 2017 | 02:57 PM
pantera408's Avatar
6th Gear
HELP AC Problems
Hello,
I have a 1996 Acura TL 3.2 that purchased a few months ago and the AC was working fine and all of a sudden the compressor will not stay engaged (when you start the car the AC compressor kicks on for a few seconds and shuts out), I've had the freon flush out and added new, changed out the high side pressure switch, the blower resistor, fuses, relays, I was wondering if the control panel had something to do with it. Please Help out with images and suggestions because I dealing with this Texas Heat. Where is the ac compressor "Cut Off" switch located?
Sean
Old Aug 2, 2017 | 11:49 PM
Crashmaster's Avatar
Who has been doing all this AC work? I would return the vehicle to that person or shop. Actually it sounds like the system is low on refrigerant. What are the service gauge readings for low and high side?
