Hello And help
Old Jul 19, 2017 | 11:20 PM
talisman1983's Avatar
Hello And help
My brake lights on 1996 Acura TL are stuck in the on position, which fuse deals with that, is the stop/horn fuse?
Old Jul 20, 2017 | 06:16 AM
brake lights always on usually means "brake switch" underneath the brake pedal has gone bad.
Old Jul 20, 2017 | 08:33 AM
Ron A's Avatar
Administrator
Welcome to the forums.
Since this is a technical issue which will require replies and not a "New Member Introduction" I moved this thread to the appropriate subsection so you can hopefully get more help.
Old Jul 20, 2017 | 07:16 PM
tempetom's Avatar
The same thing happened to me a year ago. I bought a new brake switch, but it still stayed on.
Believe it or not, there's a cheap plastic deal that actuated the brake switch, and it had worn a hole in it, thus the switch couldn't actuate.
It's either the switch or the actuator.
