heater core???
Old Apr 25, 2011 | 09:06 AM
rjameshaney's Avatar
8th Gear
heater core???
I just swapped my engine last week, before I swapped my engine, I was having a problem with "no heat". I figured the no heat issue was due to worn blades on the water pump, and figured that problem would be fixed with the engine swap. I am still having "no heat" issues. Sometimes it blows burning hot air, and sometimes it blows cold air. I also noticed, when I got the car back from the engine swap, there was antifreeze all over the drivers side floor. I figured maybe there was a spill when he was doing the engine (a friend of a friend replaced the engine for me). I cleaned it all up. Now after going for a twenty minute drive, I noticed antifreeze on the floor again. No smell coming from the vents, but there is a hissing/gasping sound coming from the dashboard, almost as if my dash is breathing, but when I turn the heat/climate control off, the breathing stops. Could this be something other than a faulty heater core?
Old Apr 29, 2011 | 09:37 AM
8th Gear
Ok, so I took the heater hoses off the pipes running through the firewall, because I am just going to bypass the heater core for now since the warm weather is here. When I took them off, I noticed that the bottom pipe (the inlet) was crushed. Im pretty sure that is the problem right there. I might not even need to replace the whole heater core, maybe just straighten out that pipe. Does anyone know a way that I could test the heater core to see if it needs to be replaced, or does anyone have any ideas on how to straighten that pipe out?
Old Apr 30, 2011 | 11:55 AM
TexasHonda's Avatar
If you can carefully striaighten the heater core nipple, you could use heater hose and water hose fittings to test. I would not pressurize to more than 10 psi and watch for leak-down.
Straightening the nipple w/o cracking it may be tricky. Take your time.
good luck
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
07Acuradude
Sep 29, 2015 03:01 PM
AcuraKidd
Sep 25, 2015 11:18 PM
